Its a few years since I had an spi, but when mine broke down, it was to do with the in-line fuses at the bulkhead, especially the absolutely vital white wire - can't remember exactly what it was for now though!
Spi Suddenly Cut Out And Now Won’T Start...
Miss Andrews
, Mar 17 2018 08:00 PM
16 replies to this topic
#16
Posted 31 March 2018 - 05:53 PM
#17
Posted 01 April 2018 - 04:36 PM
If your coil is getting hot it means it has a 12volt supply at the coil which you have replaced so if you have no spark it would look like a problem with your leads , rotor or dizzy cap. Connect a lead to the coil with a lose spark plug on the other end . This will tell you if your problem is before or after the dizzy.
