High Emission
6 replies to this topic
#1 Ronnie cook
Ronnie cook
    Starting My Mini Up
  • 1 posts
Posted 21 March 2018 - 07:44 PM
Just bought a Mini Cooper 1998 it has failed the mot on emissions what should I look for first ..this is my first mini since my 997 I had in 1970 I have brought it as a project for my retirement but I want it on the road first. Little Ron
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 21 March 2018 - 08:46 PM
Anyone local with the correct diagnostic gear? Otherwise its just a guessing game
#3 Milton
Milton
  • 54 posts
  • Local Club: what no brakes
Posted 21 March 2018 - 09:34 PM
When they did the mot emmisions test did they get the cat really hot. Problem with the spi and mpi is the cat is a fair distance from the manifold so you really need to give the engine some welly to get the cat hot enough
#4 Nu2mini
Nu2mini
  • 442 posts
Posted 22 March 2018 - 03:56 PM
As an alternative to searching out a reliable code reader you may wish to consider  the MEMS P/C based solution. Information is key when diagnosing either SPI or MPI. Having the capability to diagnose the system will always come in handy
You'll need a key to unlock this mystical world.
For a limited time only....... http://www.theminifo...g/#entry3527834
#5 Wiggy
Wiggy
  • 1,036 posts
Posted 22 March 2018 - 07:48 PM
I don't believe that will help with an MPI.
#6 Nu2mini
Nu2mini
  • 442 posts
Posted 23 March 2018 - 01:46 PM
Hi,
Sorry I may have mislead you.
As Wiggy says it may not work with MPI.
Worth checking with Sprocket on the other thread if this solution is only applicable to SPI
#7 Wiggy
Wiggy
  • 1,036 posts
Posted 24 March 2018 - 12:24 AM
As far as I know, there is no 3rd part software the 'reads' MPi Minis.
Your options are: (may not be exhaustive)
Rover T4. (V.v.expensive)
Sykes Pickavant ACR4. (fairly pricey, Rover 3 pod or later and relevant cable needed)
Details HERE
A Chinese reader called a T300. (reasonably priced but apparently a bit 'flakey' due to its dubious origin)
Or borrow any of the above.
