how do i change them?? easy job??
steering rack gators
davexdavexdave
, Oct 05 2006 09:22 AM
6 replies to this topic
Posted 05 October 2006 - 09:22 AM
Posted 05 October 2006 - 09:50 AM
Split track rod ends from hubs via ball joint seperator or other similar tool. Ttake the track rod ends off, they screw onto the steering rack, good opportunity to replace them whilst you are at it. (make sure you note there positionsing other wise your toe in will be altered), undo clips (zip ties) holding the gators onto the rack and take old ones off. fitting new ones are a reverse of this process.
Easy stuff, an hour tops to do (provided your track rod ends come off easily).
Posted 05 October 2006 - 10:06 AM
thank you
Posted 05 October 2006 - 10:29 AM
there's the catch!
Posted 05 October 2006 - 01:07 PM
there's the catch!
Your right, its amazing the amount of jobs I do on a mini which ends up needing an angle grinder!
Posted 05 October 2006 - 10:35 PM
its easier if you loosen the nut before disconnecting the track rod end from the hub, gives you something to twist against.
Especially if you dont have to 3/4 spanners or the track rod ends are those cheap ones that dont have the little gaps for the spanner to hold it.
Posted 05 October 2006 - 10:47 PM
just a quick note for the aftermath!! if you're unsure weather the tracking is ok i tink a lot of garages do free tracking check!! tho if it is out it will cost you but then again it needed it!!
