Thanks. I'm not quite sure what that chart is showing, but my needle - the BDK - appears the most "extreme" ?
The chart is showing "1000 minus the needle diameter in 10,000ths of an inch" of each of the 16 stations along the needle from idle to wide open, 1-16 respectively. The needle jet (aka the hole) is 1000/10,000 in diameter. The higher the line, the richer the mixture.
Edited by hhhh, 01 April 2018 - 05:58 PM.
