Throttle Cable
Posted 17 April 2018 - 05:41 PM
I dont need the whole cable just the inner bit. Or is it best to replace the whole thing?
Posted 17 April 2018 - 06:12 PM
Personally id replace the whole thing but thats as mine the cable has burned on the manifold and likely the internal sleeve is destroyed.,
Posted 17 April 2018 - 06:21 PM
Posted 17 April 2018 - 07:08 PM
Go to Wilkos and buy a bike inner cable. I've been running with one for the last 3 years. Just slightly modify the captive end to ensure a good fit into the throttle pedal.
A universal bike rear gear cable fits the pedal perfectly, actually it's what I replace my throttle cables with
Posted 17 April 2018 - 09:55 PM
Posted 17 April 2018 - 11:10 PM
the only issue with cycle cables is they are thinner. and the nipples generally smaller.
as to what do you need for yours it depends on what you have fitted.
i have used the same a´cable on mine with single SUs delortos webbers down draft side draft and splits. you just make brackets to work.
Posted 18 April 2018 - 05:23 AM
The gear ones have a correctly shaped end but are thinner, it's easier to mod the brake one amd keep the thick cable, justdont forget to grease it!
Fitted one to mine after 2 genuine ones failed in about a month, worked for 15 years and is still on the car (altho the car doesn't move anymore...).
Check the sleeve for wear amd heat damage, if in doubt change it.
Ben
Posted 18 April 2018 - 09:50 AM
Posted 20 April 2018 - 12:22 PM
Any tips on removing a broken cable?
Posted 20 April 2018 - 12:27 PM
depends on what the issue is. they often just fall out.
Posted 22 April 2018 - 04:19 PM
