Wheel Studs
Best Answer Mini-Hazel-Nut , 01 May 2018 - 06:12 PM
I think studs are too hard to run a die down - unless one of you knows different?
Ive cut more threads onto a stud, just take your time and use cutting compound, however its worth mentioning something I was told, which is that studs are hardened, some people say it might weaken the stud. Mine ended up being too long anyway, but I know of a couple people using died studs and have been fine (with wide banded steels and spacers!)
That`s wicked Will. Now I know what must be done. Thanks everybody but this is the best answer yet.  Hazel
Go to the full post
17 replies to this topic
#16 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 01 May 2018 - 09:45 PM
Yes I know, it could be done but it would be best to call a scrutineer for the formula to discuss the issue
#17 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 01 May 2018 - 10:12 PM
There is a company over here that have a longer fully threaded one listed on their system. There should be a similar part available over where you are
https://niceproducts...ns038-stud-nut/
#18 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 08 May 2018 - 09:46 PM
so are we going to get any info on what studs you have etc?  i would not be cutting threads. there were not cut originally due to needing to keep the strength.
and will i can not see why you need so much thread!
Studs are on hold at the moment because I`m not allowed trackside till I break the 16 second per lap barrier. The reason I "need" longer is simply that rules and regs say that if you have a nut it must be full of stud. Bloody daft taken to this extreme if you ask me, they aren`t short nuts si I reckon the stud would more likely break than pull through the nut and that aint likely either.
