I have a inertia type starter motor. Changing it last year at L2B because connect was glowing red. Been fine ever since. Then been work on her this week. Started a couple of times on the key then, kind of half turned over. Then nothing just the click of the solinode. Took starter motor off came to the conclusion that it was done, not turning when connect to battery directly either.
So new one came today, bolted on, connected up, turn the key, half turned then, click. Took it off and again wont turn when connect to battery.
Any help is welcome.
4 replies to this topic
Posted 02 May 2018 - 06:52 PM
Posted 02 May 2018 - 07:03 PM
Sounds a bit like a flat battery, try connecting another vehicle in parallel or another good battery.
Also check conditions of cables, engine earth, connection points etc...
Edited by jonlad, 02 May 2018 - 07:04 PM.
Posted 02 May 2018 - 07:28 PM
Wiggle the starter solenoid
Posted 02 May 2018 - 09:27 PM
Turns out battery was flat. But was getting 12v across it with multimeter 🤪 also turns out didnt need a new starter motor in the first place, jump leads were screwed hah!
Thanks anyway
Thanks anyway
Posted 03 May 2018 - 06:46 AM
Glad you got this sorted, just for future reference, a charged battery at rest should read 12.6v, below 12.2v is around 50% charged and below 12v is classed as discharged.
Found this out when I nearly bought a new battery for apparently no reason XD
Also tagged with one or more of these keywords: engine, electrical
engine
Mini Technical Sections →
Problems, Questions and Technical →
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , Yesterday, 08:11 AM ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
