1971 Mini 1430 Clutch Pedal Gone Solid
7 replies to this topic
#1 Mike D
Mike D
  • Just Joined
  • 45 posts
Posted 08 May 2018 - 07:07 AM
Morning folks!
  Took the mini out for a good run yesterday, all was well, so I decided to use it for work today. About half way into the journey I went to change from 4th to 3rd and the clutch pedal has gone rock solid - the car still drives and will select the gears when turned off, but the clutch doesn't seem to want to actuate.
Engine is a 1430, straight cut box, remote change pre verto for info.
Anyone able to help me out?
Cheers!
#2 timmy850
timmy850
  • 2,999 posts
  • Local Club: MITG
Posted 08 May 2018 - 07:25 AM
Do you have the two nuts on the end of the clutch plunger? If they come loose and wind in they will limit the clutch travel
#3 Mike D
Mike D
  • Just Joined
  • 45 posts
Posted 08 May 2018 - 07:40 AM
I'll have a check at lunchtime - I managed to limp it to work - edit to say it had no problems changing gear about a minute earlier
Edited by Mike D, 08 May 2018 - 07:41 AM.
#4 Mike D
Mike D
  • Just Joined
  • 45 posts
Posted 08 May 2018 - 11:58 AM
Ive been and done an investigate….
All pivots intact, slave is trying to move the clutch arm but it seems to be getting stopped by something inside the clutch cover – cant move the arm any further than the slave tries to with a bar. Also, when you push the slave all the way home, it starts creeping out again on its own
Sounds like big orange taxi home job – release bearing or diaphragm gone king dick?
#5 Dusky
Dusky
  • 5,322 posts
Posted 08 May 2018 - 01:48 PM
So, how are the throwout nuts looking?
#6 Mike D
Mike D
  • Just Joined
  • 45 posts
Posted 08 May 2018 - 01:50 PM
Throwout lock nut was loose, the one against the 'wok' was about 2mm clear
#7 timmy850
timmy850
  • 2,999 posts
  • Local Club: MITG
Posted 08 May 2018 - 09:14 PM
Try backing them right off and see how you go? It could also be something like a dud clutch arm
Edited by timmy850, 08 May 2018 - 09:18 PM.
#8 Mike D
Mike D
  • Just Joined
  • 45 posts
Posted 09 May 2018 - 06:08 AM
I tried that, still no difference - i'll get the wok off and have a look inside... I hope it's only the arm!
