Help Identifying Engine Block
17 replies to this topic
#1 RaulSims
RaulSims
  • 92 posts
Posted 04 June 2018 - 04:30 PM
Hi guys
Can someone please help me identify the engine block on the following pictures?
I know it is a pre A engine, but it has no identification tag.
Regards!
#2 nicklouse
  • 18,705 posts
Posted 04 June 2018 - 05:18 PM
might need to see some casting Numbers. and maybe some of the inside for specifics but to me it just looks like a run of the mill 1275 block.
#3 Rorf
Rorf
  • 866 posts
Posted 04 June 2018 - 05:39 PM
Does it have 2 or 4 oil gallery brass plugs, if 4 then a 1275. Also measure the diameter of the cylinders. Lastly if you put a pic up of the crankshaft clutch tail end that will help. - at a glance looks to be a 998.
Strip the crank out and measure all the journals.
#4 nicklouse
  • 18,705 posts
Posted 04 June 2018 - 05:49 PM
sorry no way a 998.
#5 RaulSims
RaulSims
  • 92 posts
Posted 04 June 2018 - 05:57 PM
I know it is a 1275, but if you noticed well on the back of the engine it has a hole that leads to channel of the oil picking to the oil pump. Is that normal?
#6 Spider
  • 15,160 posts
Posted 04 June 2018 - 06:25 PM
It's a 1275 Block, most likely from a 1275GT from approx 1976 to 1979.
Hard to tell from just a photo, but does appear to have been bored one or two times.
Of all the 1275 blocks, they are my pick.
#7 imack
imack
  • 2,207 posts
Posted 04 June 2018 - 06:58 PM
The only 1275 block I've had with that screw in plug in the back of the block near the coolant drain that goes into the oil gallery was from a 1967 austin 1300. Has it got the square casting hole above the centre main bearing? Mine had it.
#8 nicklouse
  • 18,705 posts
Posted 04 June 2018 - 08:06 PM
does it have the water drain on the rear? hard to see.
#9 nicklouse
  • 18,705 posts
Posted 04 June 2018 - 08:15 PM
is there some pics of the non S 1275 blocks for comparison? for instance this has an extra bit for the timing gear bolts
may be a thread showing the solid wall 1275 blocks could be a good sticky thread?
#10 Rorf
Rorf
  • 866 posts
Posted 05 June 2018 - 06:30 AM
Doesn't the 1275GT have a 11 stud cylinder head. Another marker would be the coolant welsh plugs on the clutch side of the block - 1275 has two and the 998 has one.
#11 nicklouse
  • 18,705 posts
Posted 05 June 2018 - 07:28 AM
nope it does not. and using the 10 studs and a bolt as a marker is poor as they can be added at any time to any engine.
#12 Rorf
Rorf
  • 866 posts
Posted 05 June 2018 - 07:33 AM
I was probably thinking about our South African 1275 GTS which had a 11 stud cylinder head.
#13 Spider
  • 15,160 posts
Posted 05 June 2018 - 08:54 AM
I think the early GTS did but I'm not sure on the later ones?
The other one that had 11 studs is the 1300 GT (ADO16).
#14 Rorf
Rorf
  • 866 posts
Posted 05 June 2018 - 12:00 PM
Good link here https://classicregis...yland-mini-gtsĀ
on SA GTS, engine was copied from the Cooper S engine - all motors were 11 stud :D
#15 RaulSims
RaulSims
  • 92 posts
Posted 05 June 2018 - 01:48 PM
Yes, it has the water drain as well.
