Do You Have To Have A Dim Dip Resistor Or Can It Be Deleted?
23 replies to this topic
#16 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 August 2018 - 04:42 PM
I bypassed mine, you need to join the blue/red and blue/brown wires that go to the pink relay under the dash. You can either use a loop wire through the relay to join the two pins or if you don't mind cutting your loom cut the relay off and join the two wires. I used the loop wire first to check it worked then cut and soldered the wires together. Have passed MOT's since.
Can I ask. Did you link the blue/red and blue brown wires together but they were still connected to the relay or did you just unplug them off the relay and connected them together?
#17 Bat
Bat
  • 903 posts
Posted 20 August 2018 - 04:53 PM
Hi,
Remove the relay and bridge them together in the socket, or better still cut the wires off and join them together by soldering or a butt connector.
Cheers  :proud:
#18 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 August 2018 - 06:18 PM
Ive seen on a land rover forum that there's a replacement bypass relay that may do it YWZ10003L. Don't know if landy and mini dim dip relays are the same
#19 MaxDempsey
MaxDempsey
  • 136 posts
Posted 20 August 2018 - 08:36 PM
First to test I made a loop wire just using the original plug but I've now cut the plug off entriely
They are the same relay I believe. Ive seen inside that relay and it is just a bar which effectively joins the wires.
#20 Sean C
Sean C
  • 196 posts
  • Local Club: ESMOC
Posted 06 September 2018 - 03:18 PM
I took Jellyboy and Cals advice and unplugged the resistor. I also cut the fingers off my rubber gloves and used them as a sock to keep the connections clean and dry should I wish to reverse the process
#21 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 06 September 2018 - 03:51 PM
That will do the job ?
#22 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 September 2018 - 03:54 PM
I ended up taking the fuse out and that sorted it
#23 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 06 September 2018 - 04:21 PM
The fuse should delete the sidelights ?
#24 Cooperman
  • 23,326 posts
Posted 06 September 2018 - 08:16 PM
I just unplugged the dim-dip connector on my 1997 Land-Rover Discovery and it was all fine.
