Lost Me Horn ...
2 replies to this topic
#1 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 01 July 2018 - 09:02 AM
Hi all,  "So no horn" removed the steering cowl ..live feed to the horn ..works.. so iam thinking its the  rotary coupling . or maybe one or both buttons . connections?
Anyone have the part number ? all i can find on ebay is YRC100410 fits rover 25.
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 01 July 2018 - 09:07 AM
One of the circuits in my rotary coupler failed. The horn worked if I set off the alarm, but the buttons didn't work.
There are 6 circuits in the Coupler, but only 2 are used. Power for horn, and earth.
What I did, was to find which circuit had failed with a multimeter. Then with a precision screwdriver, patience, and time; I managed to remove the pin from the connector on the back of the Coupler, and the corresponding pin on the horn button connector. Then I simply inserted them into a different location in the connectors. Thus utilising one of the unused circuits in the Coupler.
Worked perfectly.
#3 Wiggy
Wiggy
  • 1,036 posts
Posted 01 July 2018 - 09:43 AM
Here's some pics that may help.
Here you can see the black horn button socket on the front of the coupler, and the white connector from the back just poking its head above.
Here's the horn button connector. There's a hinged flap on the back that has to be released before you attempt to remove the pin.
And here's the one that goes into the back of the coupler. It also has the flap.
The earth (black) wire circuit was faulty on mine. So on both connectors I moved those wires one space along.
