Spi Inconsistent Idle Issues
17 replies to this topic
#16 humph
humph
    How bad can it Be?
  • 1,107 posts
Posted 20 July 2018 - 06:35 AM
There is a thread on here somewhere, can't find at the moment, where I had a similar problem resulting from failed stepper motor drivers from the ECU.  Sent the ecu away for repair & was back within 72 hours all working. At the time the repair was about £100 so I would make sure you've checked the wiring for damage before you commit just in case.
I think I used these guys
https://www.ecutechnologies.co.uk/
but it may have been these
http://www.ecutesting.com/
#17 j.gerbes
j.gerbes
  • 41 posts
Posted 21 July 2018 - 06:05 AM
So... turns out the problem may have been that the ECU plugs weren’t firmly connected.
I removed the ECU today and checked the connection of each pin between the ECU and stepper motor. There were no broken connections.
I visually inspected the pins on the ECU and the wires of the connector. There was no corrosion or obvious damage.
Plugged the ECU back in... and now the stepper motor is working perfectly and the car is idling perfectly.
I’m thinking that I may have not firmly connected the ECU when I reinstalled it after replacing the vacuum tubes. This is when the inconsistent idling problem began.
At the time, I assumed that the car had another fault. Before replacing the vacuum hoses, the car would stall when returning to idle, and after replacing them the idle would sometimes be high and sometimes low.
Problem solved, I guess?
It almost seems too good to be true.
#18 Bat
Bat
  • 903 posts
Posted 21 July 2018 - 06:51 AM
Hi,
Never knock a good result!  ;D
I would remove the connector from the ECU again and flick out the white plastic panel and check all the terminals are sitting at the same height just to make sure.
Cheers  :proud:
