I did a search but only found this: http://www.theminifo...rear windscreen
And the elements seem to be ok, and it's only the middle 'line' that works...
The elements are 'patchy', ie they are dark and light in a random fashion all over, but still the middle line works great
So should I consider getting a brand new window (£45 delivered) or could it be a problem elsewhere??
Many thanks,
Joe
Heated rear windscreen - only the middle line works?!
Gsi_Joe
, Oct 10 2006 09:51 PM
5 replies to this topic
Posted 10 October 2006 - 09:51 PM
Posted 11 October 2006 - 08:14 AM
If one line works that you are getting power to it.
Sounds like a new screen is the best option.
If you've not changed a window before then a tool for putting the filler strip in the window seal is a must, it may be worth considerinng a new strip if the old one is old and not to pliable.
Matt
Matt
Posted 11 October 2006 - 09:32 AM
if you can find the break/breaks you can get a touch up pen to complete the circuit
Posted 11 October 2006 - 09:33 AM
i think you should be greatful that even one line works
Posted 11 October 2006 - 12:47 PM
I agree with Holly, I have had numerous screen with non working. Finally found one with a couple so im happy with that.
Posted 11 October 2006 - 10:14 PM
Yeah I was gonna get a silver-pen if I could see any definite breaks in the lines, but I cant!
So is it possible that there may be a bad connection somewhere else (i.e, will a brand new one work once connected??) or is it just co-incidence that all the lines (apart from the middle!) are knackered??
I might get a silver pen then draw right along it and if it still doesnt work then i'll get a new window!
Thanks for the feedback!
Joe
Joe
