Kad Rod Change Quick Shift
25 replies to this topic
#16 WillCarter
WillCarter
  • 523 posts
Posted 16 August 2018 - 11:44 AM
All I want is the lift under the knob for reverse feature
#17 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 16 August 2018 - 11:56 AM
As I said a bit earlier....
Then get this standard gear change one made by KAD....  :-)  It's got the reverse for lift feature which is nice I have to admit!
https://kentautodeve...-rod-gear-stick
I've fitted one to Project 45.  Works great although you'll need the nylon cup to fit it and I'd suggest when you do fit the nylon cup to remove the pin at the top of the gear lever, rather than the grub screw at the bottom when detaching the internal steel cable that pulls the pin up at the bottom.  All will become clear when you get it!
#18 WillCarter
WillCarter
  • 523 posts
Posted 16 August 2018 - 12:18 PM
Will this fit directly onto a normal gearbox?
#19 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 16 August 2018 - 12:19 PM
It will indeed!  :-)
It's a lovely piece of kit.  Well all KAD stuff is really.
#20 WillCarter
WillCarter
  • 523 posts
Posted 16 August 2018 - 12:22 PM
It will indeed!  :-)
Cheers, I'll start putting a bit of money away for it then!
#21 dotmatrix
dotmatrix
  • 441 posts
Posted 16 August 2018 - 04:37 PM
I have tried both the minispares one and the kad one and the minispares one went into the bin as i welded it twice agter breaking IT in half at the pivot point. The kad one is more sturdy. But i wouldn't use it for the road.
#22 Racer_Pete
Racer_Pete
  • 2,492 posts
Posted 16 August 2018 - 06:12 PM
I had the KAD one, i loved it, was so much nicer to drive with a more positive feeling gear change, as dot says i remember years ago people on here saying about how bad the minispares one was. As they say you get what you pay for.
#23 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 17 August 2018 - 12:45 PM
Got a cheapO quick shift from a show a few years ago. Was not a quick fit and had to modify it quite a bit to get it to work but it has a nice mechanical feel when you changing gear. Also I run a bias barrel locked for 3+4 as I have not got a gate for reverse as it's also my autotest car. Never had a problem getting the gear I want.
#24 miniweights
miniweights
  • 199 posts
Posted 17 August 2018 - 08:07 PM
Unless you are driving in a wild situation like a motor race, or are a rotten driver, this is a bit of a luxury.
True, I found a thread about it saying it's very stiff, hard to fit and difficult to change from 3rd to 4th too
I love Kad's quickshift! Can only imagine there's a problem elsewhere if it's difficult to change gear.
#25 mini-mad-mark
mini-mad-mark
  • 890 posts
  • Local Club: northants wot no brakes
Posted 17 August 2018 - 08:53 PM
I've got two of the cheapo ones; one works really well but I added a couple of extra tapped holes to the mounting collar to make it more sturdy on the gear change.
The other has never worked well and I have always had trouble in the 3rd-4th gear change (but no problem anywhere else) - I've had a play with it whilst the engine was out of the car so I'll let you know if my "bodgifications" have improved things as I hope to get the car back on the road in the next week or so.
Mod/bodge is mainly sanding the plastic ball (to reduce its diameter slightly) and moving the bottom plate of the housing on its screws (slight amount of slop when you try it) to allow the lever to move slightly further to the right and back in the gate - I think that's why it doesn't work well but I'm not totally sure
In my first mini I used one of the earlier type with no lift up collar for reverse - it worked fine.
I think that came from Midland Wheels when they first appeared at the mini shows (was it that long ago?)  - their prices back then for the specific things they supply were way better than anyone else and I couldn't afford a genuine KAD one.
I just like the lift up collar reverse; the reduced travel also makes it feel better in my opinion.
#26 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 18 August 2018 - 01:20 PM
I've never had a problem using my kad quickshift, fitting it was a pain but I have a feeling that was my fault.....
YetI
