My clutch has just gone weird on me . As i press the pedal it feels like there is more resistance than usual and after driving about for a couple of miles or so ,the pedal seems as if it is sticking and not coming back up properly then as i give it a couple more presses to try to get it moving it goes solid with no travel. i have to knock it out of gear then i can get it moving again ,then the cycle starts again.
is it likely to be the clutch itself or some sort of hydrolic problem . Its a cooper ,verto type.
Not sure what to check first. Can anyone help please.
clutch gone weird
tricky123
, Oct 12 2006 07:24 PM
4 replies to this topic
Posted 12 October 2006 - 07:24 PM
Posted 12 October 2006 - 07:27 PM
sounds like a hydrolic problem to me
Posted 12 October 2006 - 10:16 PM
give the slide on the end of the bell housing a very liberous spray of wd40 or penetrating oil and the pivots on the arm let it soak in for 5 mins then pump the clutch a few times then another good spay up and it should be fine
gaz
gaz
Posted 13 October 2006 - 12:45 PM
cheers Gaz , i`ll give it a gogive the slide on the end of the bell housing a very liberous spray of wd40 or penetrating oil and the pivots on the arm let it soak in for 5 mins then pump the clutch a few times then another good spay up and it should be fine
gaz
Posted 14 October 2006 - 04:45 PM
also do under where the pedal is
i found i had this problem every time i drove in the wet
