Piston Compatability
6 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 12 October 2018 - 09:18 AM
Will all oversize pistons on offer now fit both A series and A+ conrods.
#2 Spider
  • 15,703 posts
Posted 12 October 2018 - 09:32 AM
For 998 or 1275 or something else?
#3 andyt
andyt
  • 375 posts
Posted 12 October 2018 - 12:09 PM
1275 A+, sorry.
#4 Spider
  • 15,703 posts
Posted 12 October 2018 - 05:27 PM
Generally, yes, however there are a small number of 'exotic' pistons around that have bigger Pins for the aftermarket Rods, but they are usually spelt out.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,833 posts
Posted 12 October 2018 - 05:35 PM
You need to check that your rods you have intend to use have sufficient and interference fit with the gudgeon pin to remain securely in place. For road use a minimum of 0.0008" is required. Better to have at least 0.001".
Ac
#6 Spider
  • 15,703 posts
Posted 12 October 2018 - 09:59 PM
Ac
In considering the Pin to Rod fit, this is important, but also and equally the fitting force needed to press the pin in all the way, ie, if the Rod has previously been heated for fitting Pins, then it could well have the required interference, but not the Minimum Grip needed (as as spec'ed by the Factory). The Factory advice on fitting the Pins by the way, is to do them with Cold Rods so that this can be tested and the Rods are not damaged.
#7 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 18 October 2018 - 02:29 PM
The factory Churchil tooling and manual gives a minimum torque figure for winding the pins in.
