Hello Everyone.
I have a 1993 Rover Mini Mayfair 1275.
After trying to install an aftermarket stereo my mini now won't start.
I used the existing wiring harness and plugged it into the back of the new stereo. The engine started up but there was no power to the stereo.
I turned off the engine and disconnected the stereo.
About an hour later the mini wouldn't start and hasn't since. The engine turns over but won't fire.
Does anyone have any ideas on where I should start looking?
Cheers,
Emm
4 replies to this topic
Posted 25 October 2018 - 07:09 AM
Posted 25 October 2018 - 07:42 AM
Hi,
Try a jump start or charge the battery first
If that's not done the job then check you have power to the ignition coil white wire.
Does it have electronic ignition?
Posted 25 October 2018 - 08:34 AM
Hi Bat,
Thanks for the quick reply!
I've tried a booster battery but no luck.
Yes, it has electronic ignition.
I'll check the coil and come back!
Cheers,
Emm
Cheers,
Emm
Posted 26 October 2018 - 11:21 AM
It turned out that the engine was flooded... I switched the engine on only briefly to move cars around on the drive. My fault entirely!
I've managed to get it running now and I've taken it out for a drive but it struggles to hold revs when idling. Will this improve over time when normal order has been restored?
Cheers,
Emm
Cheers,
Emm
Posted 01 November 2018 - 08:52 PM
93 car last of the Carb engines? needle valve stuck and flooding the engine ?
Mini Technical Sections →
Problems, Questions and Technical →
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
