.....a short update....after some research I decided to go with:
- AC Dodds RS camshaft
- Minspares AEG 584 followers,
- twin springs AEA 525 160lbs
- and C-AJJ4037 bronze guides
....still didn't decide which valves to use...and many other things....
...researching about Megajolt - problem is I do not have RR with any Mini experience within 1000 miles radius so I am on my own regarding carburetor and ignition one way or the other....only road testing so I am trying to grasp as much as I can because I will need it...
..back to Megajolt....if I take to the consideration wear on standard Dizzy and also need to tune it without RR with loosen springs or weights It may be that Megajolt with at least yellow Aldon map can be a good starting position without all issues with dizzy and moving parts. Price is similar as Yellow Aldon or similar dizzy and even cheaper than "123" and I can take my time to drive it and play with the map on my comp and move it back and forth to gain better performance (same as I would need to do with any dizzy..... ......whatever I do I need to do it without RR
....also crossed my mind to buy lambda and few more sensors and connect them inside the car to monitor parameters....it sounds crazy but it is few hundreds pounds investment and I can get clear picture regarding mixture and other elements and act accordingly....with RR £50-60 per hour and fact I do not have it anywhere near, £250-300 is not that bad to come closer to better tune....just thinking loud....
