Ring Gear/ Starter Motor
20 replies to this topic
#16 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 21 November 2018 - 10:40 PM
It's a retro grade step to go back to the older starter. The later pre engaged type is a higher torque unit and is much more able to crank a higher compression engine.
Ac
#17 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 21 November 2018 - 11:13 PM
Ac
Would it work though?
I can make the swap back when the time comes to change the clutch?
I'm looking for the simplest optìon...
I do appreciate though it might not be the best method from an engineering perspective.
#18 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 November 2018 - 07:37 AM
Yes it will mesh and crank. What type of engine do you have?
Ac
#19 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 November 2018 - 07:47 AM
I've got a 998 a plus which I believe to be from a metro. Looks bog standard and has cam4810 head
I bought it as a used runner to drop straight in using the ancilliaries from my 1990 a plus auto. (I'm doing a conversion)
However the starter motor I have is pre engaged. It seems the flywheel on my new engine is the inertia 107 tooth type.
I'm Trying to keep within a budget so wondering what my best option is. The car is going to be a fairweather one and only do a few thousand miles a year...
I'm doing the work in my garage. I'm not set up with oxy equipment for changing ring gear etc.
Edited by jime17, 22 November 2018 - 08:00 AM.
#20 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 November 2018 - 01:42 PM
Just fit the inertia motor. You will have to wire in a solenoid to make it work. Or remove the flywheel and buy a new ring gear. I charge £25 to remove and refit them.
Ac
#21 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 November 2018 - 04:32 PM
Ac
The chap I got it from had told me he is going to change the flywheel to one with a pre engaged flywheel so hopefully that should sort it. Thanks for the help though. I've learnt something new.
