3 Synchro Parts In A 4 Synchro Housing
10 replies to this topic
#1 Gwallace
Gwallace
    Starting My Mini Up
  • 4 posts
Posted 03 December 2018 - 09:21 PM
I've search everywhere and cant find any information on the compatibility of 3/4 Synchro parts. ( probably for good reason as i'm attempting something which defies logic :) ) So i'm hoping someone here might have hands on knowledge of the differences.
I'm putting together a 997 cooper engine and box. I have an old 3 Synchro 850 engine and box which i have stripped down. I also have the empty housing of a 4 Synchro aluminium remote gear change box (correct for the 997). The original plan (as the ratios are the same) was to put everything out of the 3 synchro into the 4 synchro on the idea i'm not too bothered about not having synchro on first.
1. is this even possible?
2. Does anyone know of any bits that are not compatible?
I've found lots of videos of putting a+ components into pre A+ box's with a little fettling but nothing for pre A+ 3/4 synchro
I'm trying to make sure i'm buying the right bearings etc I've been trying to research enough to give me a little re assurance before ordering MSG17 from Mini spares
I's assuming the synchro gears are the same for 3/4 but assume is a dirty word. or at least the word i say before i find out I've screwed it up.
The first motion shaft bearing are a bigger O/D but i'm hoping the ID is the same. Putting the two cases next to each other there seams to be very little difference other than a few oil way machining details.
All comments welcome, I'm really struggling to find any information on this one.
Thanks in advance
Gregg
#2 nicklouse
  • 19,000 posts
Posted 04 December 2018 - 12:54 AM
talk to john at Guessworks IIRC he has done this.
#3 Spider
  • 15,696 posts
Posted 04 December 2018 - 04:25 AM
Short Answer is No.
About the only parts that interchange between the 3 and 4 Synchro Boxes is the Diffs, the Final Drive Gears and the Speedo Drives.
The 3 Syncho Laygear is (from memory) 1.00" shorter from Thrust Face to Thrust Face than that fitted to the 4 Synchro and so the cases are vastly different between the two.
The ratios are also different between 3 and 4 Synchro boxes.
The correct Gearbox Case Casting No. for a 997 Cooper is 22G68. The early 998 Cooper and same period 850 Minis, shared the same Gearbox cases, but only the Coopers had the right ratios.
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 December 2018 - 11:50 AM
Its mission impossible
The laygear, mainshaft and 1 motion are different lengths and is reverse gear is different, the layshaft is shorter and parallel
The double roller bearing is smaller in a 3 syncro too and the bearings inside 2nd and 3rd are big diameter un-caged needles
Your 4 syncro remote box was never fitted to the original 997 they were all 3 syncro
Just rebuilt a 3 syncro for a really nice '66 original 998 Cooper
As Spider said they share the diff, the speedo gears and thats about it
You answered your own question in your 1st sentence.... you can only defy logic with logic
As you are using a 4 syncro box just use a 4 syncro gearset
#5 nicklouse
  • 19,000 posts
Posted 04 December 2018 - 12:26 PM
mm actually I might have been thing of something else.
#6 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 December 2018 - 12:35 PM
Did wonder...
#7 nicklouse
  • 19,000 posts
Posted 04 December 2018 - 12:51 PM
Did wonder...
may have been later 4 syncro gear set into an early 4 syncro case was late last night. but I know it was some gear set that would not normally fit in some case.
#8 Spider
  • 15,696 posts
Posted 04 December 2018 - 05:21 PM
I suspect what you may have been thinking of was fitting a 3 sychro diff cap on a 4 synchro box or viki-verka.
#9 nicklouse
  • 19,000 posts
Posted 04 December 2018 - 06:01 PM
sure it was not that. it was definatly a gearset.
#10 Cooperman
  • 23,513 posts
Posted 04 December 2018 - 11:40 PM
It is possible to fit Cooper/Cooper 'S' ratio gears into a standard ratio box of the same basic type, i.e. a 4-syncro or a 3-syncro, but not across the types.
For example, my 1990 Cooper 1275 has been fitted with gear ratios as for a late model Cooper 'S' Mk.2 or 3 with the 4-syncro Cooper remote gear-shift 'box. Lovely ratios they are too.
#11 Gwallace
Gwallace
    Starting My Mini Up
  • 4 posts
Posted 25 December 2018 - 05:36 PM
Thanks everyone for your input. It is really appreciated. I think i will just see if i can get my hands on a 4-syncro box for parts. The last month has been a bit hectic and so i haven't made much progress but hopefully the Christmas break should give me a chance to find a good donor.
