1324 Firing Order
18 replies to this topic
#1 DeadSquare
DeadSquare
  • 3,218 posts
Posted 04 December 2018 - 08:17 PM
If Mr Brown hadn't stolen 72% of my pension, I had often wistfully thought that in retirement I would get a crank and matching cam made.
Not just the usual crank though. My crank would, in effect, be sliced through the center main and the one halve rotated through 180 degrees.
This would mean that instead of getting two sucks through one side of the inlet manifold, which interfere with each other, and then two suck through the other, the sucks would be evened out and not interfere with any two cylinder's filling.
There could be a corresponding disadvantage because when cylinder 2 exhausts, gas could back-flow into cylinder 3, but this can be overcome by enlarging the exhaust port and inserting a divider in the center.
Discuss:- !
#2 Swift_General
Swift_General
  • 871 posts
Posted 04 December 2018 - 10:14 PM
I'm not sure this solves the problem. If I understand what you're saying - by rotating the crank 180 degrees between cylinders 2 and 3 each crank pin would then be 180 degress apart with repect to each other, so 1 and 3 at TDC with 2 and 4 at BDC. This would of course upset the firing order. So with your crank valid firing orders could be 1-2-3-4 or 4-3-2-1. Either way you will have 2 cylinders sharing the siamesed inlet port with sucessive intake strokes. So if 1-2-3-4 you'd have cylinder 1 on its intake stroke immediately followed by 2, so there would still be port robbing. Also the power pulse will either make its way up the crank towards the flywheel or away from it rather than the pulses being distributed more evenly. I'm guessing 1-2-3-4 will set up an oscillation - so as the plugs fire moving along the crank the engine rocks one way, then pings back as the process starts again.
#3 nicklouse
  • 18,771 posts
Posted 04 December 2018 - 10:17 PM
boring. just super charge it and blow through the exhausts and out through the inlets. cam ground to suit. has has been done before though.
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 December 2018 - 10:19 PM
This is a real brain twister
I have wondered about similar for years as it makes sense
After an A4 of working out...
The standard firing order is 1 3 4 2 so by swapping the crank phasing at one end 180 degrees it changes things
So cylinders 1 / 2 don't change... 3 and 4 effectively swap round
So the crank instead of having 1 / 4 at BDC and 2 / 3 at TDC as standard....1 and 3 are at BDC and 2 / 4 are at TDC
So the firing order would be  1 4 3 2   according to my scribbling
So all the standard A series charge robbing etc would still happen
The firing order can't be 1 3 4 2   as with the crank re-phased 1  and  3  are on the same stroke [ up or down ] at the same time
So if 1 is firing 3 must be filling etc
So in theory the 1 3 4 2  firing order might be as good as it gets on an A series but just re-phasing 1/2 the crank would not do it
I wonder would it work with cylinders 1 / 2 phased opposite to 3 / 4
More scibblings needed
#5 Swift_General
Swift_General
  • 871 posts
Posted 04 December 2018 - 10:36 PM
The only way to solve this on a 4 cylinder engine is to have 1 and 2 at TDC with 3 and 4 at BDC. So a valid firing order would be 1-3-2-4 (i.e. as per title of thread). But this means rotating the crank 180 degrees between 1 and 2, between 2 and 3, and 3 and 4 to get cranks pins 1 and 2 inline, and 3 and 4 inline and 180 degrees relative to 1 and 2. This would certainly deal with the charge robbing issue, but I suspect there would be a issue with the balance of the crank.
#6 DeadSquare
DeadSquare
  • 3,218 posts
Posted 04 December 2018 - 10:44 PM
Edited by DeadSquare, 04 December 2018 - 11:21 PM.
#7 Swift_General
Swift_General
  • 871 posts
Posted 04 December 2018 - 11:01 PM
You are correct. It should be 1432.
But this doesn't solve the charge robbing problem. As you'll have cylinder 1 intake immediately after 2, then cylinder 3 intake immediately after 4.
#8 DeadSquare
DeadSquare
  • 3,218 posts
Posted 04 December 2018 - 11:18 PM
Well it looks as though, as it doesn't seem to work, that it is just as well that I haven't got the money, to waste !
#9 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 04 December 2018 - 11:58 PM
The  1 3 2 4 firing order would work with the crank phased  1 / 2 at TDC  and  3 / 4 at BDC
But would it work balance wise ?  with both ends of the crank dead opposite ?
I think it would be more of a flex and strength problem
as rather than having 2 big ends opposite each other at each side of the centre main, it would have 2 big ends at each side....
Probably stressing and flexing the centre main too much
That said a pension pot would probably not be big enough to investigate
#10 Spider
  • 15,254 posts
Posted 05 December 2018 - 02:00 AM
I recall scribbling something down a while back on these kinds of configurations.
The Harmonics from just about any other order than the 'standard' 1,3,4,2 would become a headache.
I ** think ** too, you may need Balance Shafts.
#11 Steve220
Steve220
  • 5,084 posts
  • Local Club: BMC
Posted 05 December 2018 - 08:12 AM
You would. It'd shake like a poopin dog otherwise.
Edited by yeti21586, 05 December 2018 - 05:45 PM.
Don't try and avoid the swear filter
#12 CMXCVIII
CMXCVIII
  • 374 posts
Posted 05 December 2018 - 09:14 AM
It does look as though Gordon Brown stealing your pension saved you from shaking your teeth out!
And presumably investing in ever bigger and stronger centre bearing main straps!
Jon
- ETA - I'd missed Retroman's 'further scribble' that already made that point
Edited by CMXCVIII, 05 December 2018 - 09:18 AM.
#13 mini13
mini13
  • 3,811 posts
Posted 05 December 2018 - 09:18 AM
the 1&2 up 3&4 down crank has been done before, I remember vizard mentioning it somwhere, but didnt say how good or crap it was, IIRC it was an inline motor built for a sprite in Aus.
#14 DeadSquare
DeadSquare
  • 3,218 posts
Posted 05 December 2018 - 10:25 AM
Pursuant to yesterday evening's excellent posts, at quarter to five this morning, I went and found my Meccano.
I have made a 3 main bearing shaft, in such a way that I can change the angle of the cranks.
After a couple of hours of fiddling, I have come to the conclusion that there is only one design that produces the desired firing order.  For simplicity of explanation only, cylinders 1&2 share a crank pin, (there would be plenty of room for a counterbalance blade between the big-ends), and 3&4 share another.
The firing order can then be either 1324 or 1423.
#15 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 05 December 2018 - 12:30 PM
Back to childhood excellent....So we are all singing from the same sheet
Would be interesting to ask DV, if it was Aus Spider might know...?
Does DV still do forums now ? he used to be on piston heads
    Bing (1)
