More Clutch/gearbox Woes
Best Answer Its a min , 12 February 2019 - 10:31 PM
Hi all,
As with my other post, I just wanted to give a quick update to let you know it seems to be all sorted. Looks like it was a combination of new c-clip/backing ring being slightly over-sized, so no primary gear end float, and when I fitted the clutch plate, I didn't leave the pressure plate loose enough for the clutch plate to centre itself before torquing up the pressure plate causing the whole flywheel/clutch assembly to be unbalanced. Now, I have smooth gear change with both the engine running and not!
Thanks for all the help and advice.
Go to the full post
48 replies to this topic
#46 Rorf
Rorf
  • 866 posts
Posted 13 February 2019 - 07:02 AM
Well done for eventually finding the problem - happy mini motoring.
#47 andyapanel
andyapanel
  • 651 posts
Posted 13 February 2019 - 08:19 AM
It's always good to read a happy ending.
#48 Its a min
Its a min
  • 284 posts
Posted 14 February 2019 - 01:18 AM
Cheers guys.
Rorf, a special thanks to you for all your help/advice with this and other posts of mine.
#49 Rorf
Rorf
  • 866 posts
Posted 14 February 2019 - 03:52 PM
Cheers guys.
Only a pleasure, I have also learn't a tremendous amount from this forum in the last few years even though I have worked on my mini on and off since 1991. I am now busy with a full nut and bolt and body restore.
