Compression Ratio And Engine Identification.
#16
Posted 19 December 2018 - 09:19 AM
#17
Posted 19 December 2018 - 07:47 PM
The 99HE21 was also 9.6:1. The engines are very similar in fact, only the Auto Engine from your Mini was factory fitted with a HS4, which is what you say you have.
You may wish to consider swapping the heads over, the only reason I suggest this is because the head from the 99HE should be unleaded suitable.
Distributor wise, curiously, the curves were different.
the 99HE21;-
(On deceleration)
18 deg at 4800 RPM
15 deg at 3700 RPM
8 deg at 2000 RPM
0 deg at 400 ROM
the 99H907B;-
22 deg at 4800 RPM
16 deg at 2800 RPM
12 deg at 1500 RPM
1 deg at 600 RPM
0 deg at 400 RPM.
You'd possibly get away with the distributor from the 99HE21, but it wouldn't be ideal at all.
#18
Posted 19 December 2018 - 08:53 PM
I was going to change the head because as you said it's definitely unleaded. I can't be sure of the one I'm using now until I remove it and the valves...
I will see how I get on with the current distributor but I could always get it re curved.... I assume that isnt a diy job?
Edit... Hope this isn't a daft question but why would two engines with the same displacement, CR and carb size and presumably the same cam require different advance curves?
I'd guess with my limited knowledge that it would be because of the fact one was made with unleaded fuel in mind and the demands of an automatic transmission and different final drive require different advance curves. I'd be interested to know the actual answer though.
Edited by jime17, 19 December 2018 - 09:10 PM.
#19
Posted 19 December 2018 - 09:18 PM
You certainly have loads of info to hand.
I often wish it was 'to hand' but probably 70%+ of what I do have (like this stuff) is still on micro-fiche - YUK !!!!!
Without studying it, off hand, I'd say it's due to one being set up for Leaded Fuels and the other for Unleaded. They do burn quite differently.
#20
Posted 19 December 2018 - 09:43 PM
Well then I really thank you for trawling through that. I do appreciate it.
Edited by jime17, 19 December 2018 - 09:44 PM.
#21
Posted 19 December 2018 - 09:49 PM
So thinking about what you said. if I'm using the distributor from my auto with the same CR which was curved for unleaded fuel then it should actually be curved correctly no?Without studying it, off hand, I'd say it's due to one being set up for Leaded Fuels and the other for Unleaded. They do burn quite differently.
Edited by jime17, 19 December 2018 - 09:54 PM.
#22
Posted 20 December 2018 - 08:07 AM
I think you're trying to pull my finger nails out one by one here,,,,,,,
OK the Camshafts between the engines have different Timing and this would be the most likely reason for the different advance curves.
The 99HE21;-
In Opens 5 deg BTDC
In Closes 45 deg ABDC
Ex Opens 40 deg BBDC
Ex Closes 10 deg ATDC
The 99H907B;-
In Opens 9 deg BTDC
In Closes 41 deg ABDC
Ex Opens 49 deg BBDC
Ex Closes 11 deg ATDC
#23
Posted 20 December 2018 - 08:37 AM
Oops. Sorry its probably more a case of me trying to understand more than I should given my overall knowledge of the subject. I also suspect I'm trying to delve too deep when I'm just looking for a drivable weekend car rather than trying to eek every last horse out of it.I think you're trying to pull my finger nails out one by one here,,,,,,,
Especially as you can't just cut and paste from microfiche!
I can see now why the dizzy curve might not be optimum and leave it at that. Sincerely thank you for all the effort you've gone to Moke. You've answered a lot of my questions.
Thank you to all the other contributors too.
Edited by jime17, 20 December 2018 - 08:53 AM.
