Panel switches conversion - wiring help
Jordie
, Oct 15 2006 09:19 AM
12 replies to this topic
Posted 15 October 2006 - 09:19 AM
Hello all.
I am in the process of fitting a Saxo VTR dashboard into my mini. I am going to use the saxo switches, but i figure I will have problems when it comes to the wiring differences.
I have not yet taken delivery of the switches (i will go for them this morning).
I have looked at the haynes and the workshop guide on the TMF cd, but the wiring diagrams are hard to understand. I am looking for a diagram of each switch with named/key coded wires so i can figure out which i need to attach on the saxo switches.
If anyone can help, that would be great. Chow for now.
Jordie
Jordie
Posted 15 October 2006 - 09:54 AM
things like lights, heater and back window heater should be easy a switch is just a switch
the hazard lights migt be the one that is not easy i dont know how a saxo system works
Posted 15 October 2006 - 10:10 AM
Best thing is if you could get a clear photo of both the front and back of the switch panel and then post them up, so we can work out which wire goes where.
Posted 15 October 2006 - 10:31 AM
On the same subject, hope I'm not thread stealing, does anyone have a logic diagram of the hazard switch? I just cant figure it out and the Paynes doesn't have one.
Posted 15 October 2006 - 10:50 AM
the two top terminals on hazard switch are like an on/off for you're indicators so u cant use both at the same time!! just takes power in and thru to the indicator switch!!
the bottom four!! 1 of them is the signal in from the hazard unit, the other 3 are light bulbs, green/white is right side, green red is left side and i think its green pink for the hazard switch light!!! as for diagrams err!! what are you trying to do with it!! replace with a single switch??
Posted 15 October 2006 - 10:54 AM
Thanks fikus, no I'm not replacing it (yet) Just trying to figure out why it doesn't work
Posted 15 October 2006 - 11:12 AM
usually with hazard switches if the hazard relay is ok and the fuse hasnt gone (interior light works on same fuse!! behind carb!!) then the switch will be in need of a clean!! its not too hard to get them apart if you're feeling adventurous!!
Posted 15 October 2006 - 01:04 PM
Here are the saxo switches for rear heater and hazards.
Dont know how i am going to do the headlights yet.
Sorry about quality, no batteries left or good light.
Rear heater
As you can see, 5 prongs on that one.
Hazards
This has 8 prongs.
Both should illuminate as far as i know.
I am going to join a saxo forum and see if anyone has a diagram for which prong is what.
Rear heater
Hazards
This has 8 prongs.
Posted 15 October 2006 - 01:43 PM
As anyone pictures of the rear of the original mini switches??? Diagram would be even better as i cant get access to my car right now.
Posted 15 October 2006 - 06:16 PM
Right ive got the heated window switch wiring diagram. Can anyone work it out?
Turning the heater switch on its side. the pins line up with the lower 1 3 5 6 7 section.
I rekon, 6 is a postive wire for the light
7 is a earth
1 is not needed
3 also not needed
5 is a postive wire
I rekon the 1 and 3 are some sort of 2nd switch to do with the air con if fitted, so i can bypass these. anyone like to comment?
7 is a earth
1 is not needed
3 also not needed
5 is a postive wire
Posted 15 October 2006 - 06:28 PM
This is the hazards, god help me.
Posted 15 October 2006 - 06:36 PM
looks like you need a multimeter. that will help you figure out what does what
Posted 15 October 2006 - 06:41 PM
aye, ive got one. Gunna get some wire and check each pin on a spare 12v battery.
