shaking when braking.
Posted 16 October 2006 - 08:25 AM
Bit of an annoying problem on Sir D at them oment where by any firm braking results in the car shaking...earthquake trembling kinda thing. I haven't had the chance to properly look at the disk brake area, but am sure its the front driver side system. This was not damaged when Sir D hit the Polo, but you can never tell if the wheels been affected form stopping suddenly.
Can anyone shed some light? Brake system is 8.4" MPI caliper.
Thanks.
Posted 16 October 2006 - 08:40 AM
Hey folks.
Thanks.
could your discs be warped???? are you sure the pads are fitted securley?
Posted 16 October 2006 - 08:44 AM
thanks
Posted 16 October 2006 - 11:26 AM
Most claim warped discs, but personally I have never actually seen or experienced and true warped disc. What it always turns out to be is uneven carbon build up on the face of the disk. Either that or another problem, such as a suck piston on the caliper.
Also a warped wheel or out of balance wheel can cause a similar affect, but you'd normally motice it under accelaration also.
If the whole car is shaking as opposed to mostly the pedal and steering wheel then it may be more attributed to some form of worn or miss alignment in the drivetrain/suspension setup.
Discs are pretty cheap as are pads. Personally I'd probably chuck some new ones on and see if it clears it up.
Posted 16 October 2006 - 12:55 PM
Posted 16 October 2006 - 01:16 PM
I could be wrong though.....
Posted 16 October 2006 - 01:53 PM
Posted 16 October 2006 - 02:11 PM
IMHO alot of wobbly brake syndrome is caused by either siezing calipers or sliders (OK, so sliders not relevant on a Mini with the two pot setup). Or by loose components.
Check that there is no play in the wheel bearing by jacking the car up and putting it on axle stands.
Check that the wheel turns freely and releases freely. Check that your pads are in OK condition whilst at it too. Also make sure that your brake rotors aint too badly scored or worn.
Posted 16 October 2006 - 05:39 PM
Posted 16 October 2006 - 09:25 PM
Err to someone else's question, its the steering wheel as well that shakes - general shaky sound as well.
One note I should add - the near side tie bar is bent - would that make such a difference?
Posted 16 October 2006 - 09:45 PM
and the bent tie bar probaly won't help matters.
Posted 17 October 2006 - 09:35 AM
Posted 17 October 2006 - 09:41 AM
My money's on the warped disk thing.
Matt
Posted 17 October 2006 - 03:57 PM
Posted 17 October 2006 - 04:11 PM
best thing is to take of the wheel and get your brother to press the brake pedal gently just to make sure both pads move then turn the hub still with brake pedal pressed very gently to see weather the pads move back and forward in the caliper
i think it might be the piston sticking slightly but could be tracking wheel balancing or just general suspension set up somewhere
