Flywheel Housing Removal
Posted 16 October 2006 - 08:57 AM
My engine is a 998 cooper engine which has been rebuilt and done 1500 miles since rebuild.
Yesterday I noticed a patch of oil under my car about 4 inches diameter under the car (it seems to have come from the area where the flywheel housing bolts to the crank case).
On further inspection, the bottom of the joint is wet with oil. Could this be a gasket problem? Or, could the retaining nuts have worked loose, and need tightening?
My main question is this: If I had to remove the clutch and flywheel housing to fit a new gasket, is it possible to remove the bell housing, and fywheel housing with the engine still in place?
Please bear in mind that I have never done anything like this before, so how easy or difficult is it to do and what problems would I likely be faced with?
John
Posted 16 October 2006 - 09:12 AM
hi mate 1st are you sure its coming from the gasket and not the crank oil seal behind the clutchHello
John
and 2nd yes you can take the flywheel housing off the engine while its still in the car and as for difficulty it not that difficult to do just awkward and fiddly but depends on how your mechanics are?
HOPE IT HELPS
Posted 16 October 2006 - 09:19 AM
As Andy said, it could be the Oil Seal, either way your going to have to take the covers off and then it should be easy enough to tell. Have you noticed any clutch slip?
Posted 16 October 2006 - 09:48 AM
Posted 16 October 2006 - 09:52 AM
Posted 16 October 2006 - 09:53 AM
Thanks for the relpy. I will check exactly where the oil is coming from by cleaning the engine as much as possible, especially so I know if it is coming from the diff housing (and running to the bottom of the engine or not) . As for my mechanics, I have had no mechanical training on vehicles, so i am a little worried about doing this stuff.
How much would a garage charge for doing this stuff?
Posted 16 October 2006 - 10:03 AM
Edited by TOMMO0302, 16 October 2006 - 10:04 AM.
Posted 16 October 2006 - 10:16 AM
I personally hate working on the floor, so I'd rather spend an hour poppin the engine out and have it on a bench to do the work. It can be done in place, but it aint the easiest way.
You have to support the engine from above, remove the engine mount, remove the slave cylinder, clutch cover, take the starter motor out, lock the flywheel in place, then remove the flywheel, then the transfer case, then you can get to the gasket, unless it is the crankshaft oil seal as said above, in which case you follow the steps until you get the flywheel off, then you can access the seal, which can be changed easily with a special tool.
As said above ^^^^^, it makes sense to be 100% certain about the leak before you do a strip down.
Posted 16 October 2006 - 10:32 AM
Thanks for that. I will next clean up the area to see exactly where the oil is coing from, but on initial inspection, everywhere else was pretty dry except fpr the bottom nut of the flywheel housing (next to the block). Please bear in mind I am no mechanic, so is it just a case of following the Haynes manual?
Removing the engine really scares me!!
John
Posted 16 October 2006 - 10:59 AM
Have you tried to see if that bolt is tight? It may be that it has not been correctly tightened. It may be that the (EDIT) gasket is damaged around that bolt area.
Plus, where abouts do you live?
There may be someone off the forum who lives near you and would be willing to lend a helping hand in return for beer or fodder.
When you say the flywheel housing, do you mean the clutch cover (the roundish cover with the engine mounting bolted on the bottom) or do you mean the transfer case bit? In other words, the bit with a red blob on it, or the bit with a blue blob on it?
Edited by mini mad me, 16 October 2006 - 10:59 AM.
Posted 16 October 2006 - 11:18 AM
I live in Milton Keynes by the way, anyone there you know who can help?
John
Posted 16 October 2006 - 11:21 AM
John
Fraid not, but someone else on here may live around there. I should have guessed by the MK in yer user name!
