more rad help
chrisg
, Oct 16 2006 01:58 PM
13 replies to this topic
Posted 16 October 2006 - 01:58 PM
posted a problem with my rad fan catching last week on the bottom of the cowling. I trimmed the fan down a bit and it stopped it catching as much. thought id drive it to see which blades were still catching before takeing any more off. took it for a long run this weekend and it gradually started to catch more and more. it was ok when running but sat in traffic on way back in D (auto) the rad went fairly sure fan hit it. Any one know what might be causing it to catch more some time and not others and how to fix before fitting new rad and having it happen all over again?
cheers
p.s check pic for major fan damage.
cheers
Posted 16 October 2006 - 02:01 PM
if you can, run the engine and look to see if the fan wobbles.
might be the water pump is bugger and needs changing. well.....thats the only thin i can thing of.
Posted 16 October 2006 - 02:13 PM
You may well need some extra/bigger rad fan spacers mate! And those modifications wouldn't aid cooling-sorry, i'm sure you know that but i would suggest a new fan and some more/less spacers! I currently have 3 (i think) 5 mm spacers on mine as had a similar problem.
Posted 16 October 2006 - 02:21 PM
could be the water pumps as said before might also be the bushes that hold the rad in place best thing if you still have it fitted is grab the near the base and try to wobble it if there is no movement back and forward then grab the top of the rad move that back and forward then left and right tis the only things i could think of
when mine went it was the water pump but it might not be the case with yours
Posted 16 October 2006 - 02:45 PM
Can you provide a pic from above the engine, to the side of the rad (say, stood at the drivers wing) of the rad? It looks to me like your top rad bracket is quite bent, but also that the rad is sat at quite an angle.
Posted 16 October 2006 - 03:13 PM
Motor mount sagging?
That's what mine was.
New mounts all around including torque arm.
Posted 16 October 2006 - 03:34 PM
just had a look the bottom bracket is broken dont know when this happened it looked ok a week ago but cant be sure so think its going to be a new braket fan, rad and spacers to sort it.
Posted 16 October 2006 - 03:37 PM
Good luck mate, let us know if that sorts it!
Posted 16 October 2006 - 04:55 PM
The rad is sitting too high.
Is the bottom bracket fitted correctly
Or
Is this an 'auto' engine with a 'manual' bottom rad bracket???
Or
Edited by Mini Sprocket, 16 October 2006 - 04:56 PM.
Posted 17 October 2006 - 11:44 AM
The bottom bracket is broke got a mecanic to have a look at itand the engine mounting bracket has broke and the engine had droped about an inch, causeing the whole problem.
Posted 17 October 2006 - 11:48 AM
thats not good hope you get it sorted soon mate
Posted 17 October 2006 - 07:55 PM
ur lucky ur fan didnt start to depart the engine bay like n 11 cartridge ninja death star!! i had 1 that cut my bottom rad hose clean in 2!!!! it decided to go wrong at about 6500rpm on a country lane blag!! certainly made one hell of a noise!!!!
Posted 27 October 2006 - 10:59 AM
hey guys
thanks for the help
got a new engine mounting on now and seams to have done the job. no longer sounds like the wolds coming to an end while driving it.
thanks for the help
Posted 27 October 2006 - 11:09 AM
good stuff
