Rust Converter
18 replies to this topic
#1 Jase
Jase
  • 1,166 posts
Posted 27 February 2019 - 09:08 PM
What do people currently use to purify rust? Just about to grind back some surface rust and I want to make sure it is converted. Just wondering what are the most effective treatments prior to priming.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 27 February 2019 - 09:14 PM
Bilt Hamber Deox gel.
#3 johnno23
johnno23
  • 18 posts
Posted 27 February 2019 - 09:32 PM
10% citric acid mixed with wallpaper paste similar to Deox C, Rinse afterwards with warm soapy water. brilliant.
#4 Jase
Jase
  • 1,166 posts
Posted 27 February 2019 - 09:45 PM
What about Jenolite?
#5 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 27 February 2019 - 10:06 PM
I use Kurust
#6 Icey
Icey
  • 1,553 posts
Posted 27 February 2019 - 10:18 PM
I don't think I've ever seen 'surface' rust on a Mini apart from on the subframes. If body panels are rusting there's usually a deeper reason that can't be fixed without a welder.
So to answer the question, none. A grinder with a knot-brush or linishing wheel for cleaning up rusty subframes. If it's panels, a 1mm slitting disk and/or a spot-weld drill-bit with a visit to a panel supplier.
#7 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 27 February 2019 - 10:29 PM
I do agree with this, then use Kurust(or equivalent) to prevent any rust growth in the welds
#8 Jase
Jase
  • 1,166 posts
Posted 27 February 2019 - 10:31 PM
It's actually not for a Mini, just wanted some advice for a converter.
#9 MikeRotherham
MikeRotherham
  • 987 posts
Posted 27 February 2019 - 10:44 PM
I'd try the Deox Gel first.
You have to follow the instructions to the letter though even though it seems like a huge faff.
#10 Chris1992
Chris1992
  • 2,022 posts
Posted 27 February 2019 - 10:55 PM
I use Kurust which seems to do the trick!
#11 Jase
Jase
  • 1,166 posts
Posted 27 February 2019 - 11:01 PM
Thanks, just ordered Jenolite, remembered using this many yers ago. Thanks for the advice, gave me something to research from.
#12 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 28 February 2019 - 06:38 AM
I use Hammerrite green gel and or Por 15 de ruster. the trick ist to keep it all wet, so cover with PET or cling film and let the rust remover work as long as poss.
Rust converter is some what miss leading, Jenolite and most of the others just seal the rust and turn it black, The rust is still there and will rust on.
If you have heavy rust then cutting it out and replacing is the only answer.
and dont think these rust removers will work wonders they dont.
#13 pete l
pete l
  • 1,375 posts
Posted 28 February 2019 - 09:09 AM
Forget the KURUST etc. they call this a rust convertor. basically, if you leave rust or "convert" it, it will come back.
Use DEOX gel, it is a rust REMOVER and it works.
#14 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 28 February 2019 - 11:16 AM
Yea the stuff from Bilt Hamber is really good.
#15 MikeRotherham
MikeRotherham
  • 987 posts
Posted 28 February 2019 - 02:56 PM
With the Deox, provided the rust is not too deep you are left with bright shiny pitted metal that you just need to cover over with something to protect it.
