car temp's
Posted 17 October 2006 - 12:00 AM
I was in bad traffic the other day, and my car temp's was just past half way. is this normal, as ive never had my car stand still for so long in traffic like that b4. my idle went up to 1500 rpm as well.
Posted 17 October 2006 - 07:40 AM
could just need a change.
Posted 17 October 2006 - 08:43 AM
Most cars will run hotter sat in traffic like that, mine ceratinly all have. Unless the temperature keeps creeping up then I wouldn't worry about it.
Posted 17 October 2006 - 04:56 PM
mini's do tend to get a little toasty in traffic but check the rad fluid is still nice and clean.
I checked the water today, and its all gunky with like cooper looking gunge.
What shall i do to clean it all out, best way. my rads at the front tho. thanks
Posted 17 October 2006 - 05:05 PM
Posted 17 October 2006 - 06:43 PM
Coppery stuff= rust! Remember you have a cast iron engine block, which has heat and water flowing through it. The perfect opportunity for iron to rust. I am sure there is a description of flushing your engine/radiator somewhere on here, else consult the Haynes book of lies for details. Its perfectly natural for a Mini to have that colour in the water. As long as there is not too much sludge, and as long as there is NO mayonnaise, its fine!
It's mayonnaise all right lol I better check around on best way
Cant find best way on here to flushing your radiator
Edited by Mark1275GT, 17 October 2006 - 06:51 PM.
Posted 17 October 2006 - 06:51 PM
if its brown gunk, more like barbecue sause or the aftermath of a vindaloo then a flush shud be ok!!
Edited by fikus01, 17 October 2006 - 06:52 PM.
Posted 17 October 2006 - 06:56 PM
by maonaise (white gunk) im assuming you're referring to oil and water mixing which would cause concern!!
No its Coppery. just got find best way to flush it all ?
Posted 25 October 2006 - 12:25 PM
As far as I know the a-series engines will run reasonably warm temperature wise, just check the fan is spinning correctly and that there are no water leaks etc.
Posted 25 October 2006 - 12:45 PM
If its creamy mayo colour this would point towards a head gasket failure which in turn over time would cause overheating issues. If it is just rusty water coloured then dont worry about it, it will be fine if you are worried just flush the water out and replace with the correct coolant mixture (30 coolant / 70 water).
My chap does know what he is on about so I hope this helped ya
Posted 25 October 2006 - 04:51 PM
Change water and put anti freeze in side.. run much better.. was rusty colour.. thanks
