Best Answer Bobbins , 13 March 2019 - 03:37 PM
Lucas double connectors: https://www.carbuild...-pack-of-10-ten
Lucas single connectors: https://www.carbuild...connectorjoiner
Go to the full post
Posted 12 March 2019 - 11:26 AM
Looking for some help connecting my headlights and indicators to the main loom.
The indicators - I just need to know if the black or green/red should go to a particular connecting point or if it doesn’t matter?
The headlights - I bought the loom mini spares said I should. I have a sealed beam headlight so don’t need the sidelight wiring. However my main loom has two connecting point, black and green/red. The headlight wiring loom has possible 3 cables I can connect. Black, blue/white and blue/red... was wondering which two I connect to the black and green/red?
Posted 12 March 2019 - 12:19 PM
Edited by BJPclassicmini, 12 March 2019 - 12:21 PM.
Posted 12 March 2019 - 12:23 PM
Posted 12 March 2019 - 12:39 PM
Hi Guys,
Black is always -ve ("earth" in a car)
Green/red is the indicator live (+ve)
Blue/red is the headlight live (+ve)
Blue/white is the headlight high beam live (+ve)
Posted 12 March 2019 - 12:41 PM
For your indicator bulb, the black is connected to the flange, the green/red is connected to the bulb end (bottom connection in your photo).
Posted 12 March 2019 - 01:14 PM
A little confused with the comment on the headlight wiring.
The green/red wire and black wire in the second picture are for connecting to the headlight loom (red, black, blue/red, blue/white)
Posted 12 March 2019 - 01:34 PM
There are standard colour codes for British cars, anything you have on the original wiring that doesn't conform with the codes you will need to check what it is, or someone here might be able to give you guidance. It's worth trying to keep to the correct colour codes to make fault finding easier. See the attached pdf.
Posted 13 March 2019 - 10:18 AM
UPDATE:
I have since found what I think is the right point of connection?
Next question is how do I attach both headlight looms to this? As it’s the only wiring on the main loom that matches the colours.
Posted 13 March 2019 - 11:01 AM
Thanks a ton for the help.
UPDATE:
Can you explain your problem in more detail, it's not clear what you're struggling to do?
Posted 13 March 2019 - 11:14 AM
There two black which will connect.
I need to know the best way of connecting the blue/white and blue/red from each headlight loom to the one blue/white and blue/red in the loom.
Sorry for any confusion.
Posted 13 March 2019 - 02:15 PM
Do you mean the black sleeves that connect the bullet ends together???
Posted 13 March 2019 - 03:12 PM
Posted 13 March 2019 - 03:37 PM Best Answer
Posted 13 March 2019 - 03:44 PM
Thank you for taking the time to solve it!
Mini Technical Sections →
Problems, Questions and Technical →
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
