Steering Column
19 replies to this topic
#16 28hodge
28hodge
  • 223 posts
Posted 13 March 2019 - 10:55 AM
That drop bracket is a adding a pivot, at least make sure it's arranged so both of its fixing points are in line and perpendicular to the column, not forming a dog leg.
Suppose someone ought to mention slackening the rack U bolt nuts while you adjust the angle of the column so it can align and not stress the splines connecting the two.
Yeah I knew to slacken those bolts but definitely worth stating it for safeties sake.
#17 GraemeC
GraemeC
  • 7,438 posts
Posted 13 March 2019 - 07:03 PM
One of these from Tom Kidd (lives near Forton):
https://kiddspeed.bigcartel.com
#18 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 March 2019 - 07:50 PM
With clarification on the movement, undo the pinch bolt on the column to rack,undo the 3 wiring plugs at the base of the cowling and whip the column retaining bolt out the bracker and have a good look at the column bushes
#19 28hodge
28hodge
  • 223 posts
Posted 13 March 2019 - 08:37 PM
https://youtu.be/7MMgirbWEJg
Top bush wear from what I can see?
#20 28hodge
28hodge
  • 223 posts
Posted 13 March 2019 - 08:39 PM
Ta, looking at mine tonight I might not have a minispares on and there is zero play in it
