Vauxhall powered Midas
17 replies to this topic
#1 Artstu
Artstu
  • 832 posts
Posted 17 October 2006 - 09:11 PM
I don't think for one minute that this conversion will be easy or happen quickly, the fact that I can't weld and have limited garage facilites doesn't help matters either.
This is the Metro subframe that I hope to fit a 2.0L XE engine to, although I also have a C16SE engine that is a good deal lighter and smaller that I may end up putting in, the 2.0 one might just work out too big.
Here's the F13 in the subframe, I think I have an awful long way to go.
Standard ................................................................ With chunks taken out
Edited by Plastic rules, 24 October 2006 - 01:56 PM.
#2 Apollo32_2000
Apollo32_2000
  • 88 posts
  • Local Club: Welsh Boarders
Posted 17 October 2006 - 09:14 PM
Best of luck.. lets just hope it doesn't gather to much dust on the garage floor.
#3 Artstu
Artstu
  • 832 posts
Posted 18 October 2006 - 12:22 PM
Thanks Apollo, I hope so to, as the subframe is off the car I can't for the life of me get the nut undone on the end of the driveshaft, that's always the first job I do when working on the front suspension. A local garage should help me out with their air impact-gun, I just need to get the hubs off and then wheel-barrow them to the garage.
I'm going to ditch the anti-roll bar and put mini bottom arms and tie bars on for adjustability and I'm going for a coil-over damper similar to the MGF TC, I'm going to try and use the original top-arm, whilst a friend who is doing the same conversion using a C16SE is going to try it with the TC top arms.
Not a lot done today, you'll get used to those words unless you get bored althogether.
#4 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 18 October 2006 - 12:30 PM
Good luck! As long as you keep lots of pics coming people won't get bored! But updated pics are always best! :ermm:
#5 metro1275
metro1275
  • 126 posts
Posted 18 October 2006 - 12:56 PM
best way to loosen a stuck nut is a breaker bar and a scaffolding tube :ermm:
#6 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 18 October 2006 - 02:16 PM
Im guessing your Plastic car is mini based, otherwise you would already have a K series in it? So why not use a mini front subframe? Or are you after the wider track width?? :ermm:
#7 Artstu
Artstu
  • 832 posts
Posted 18 October 2006 - 08:07 PM
I'd need someone heavy to stand on the subframe with the scaffold tube technique.
I have three Midas, one is Metro based, the other two mini based, I also have an Allspeed frame for the mini based one, but the car sat in the garage with no wheels is the metro one, I can do a bit at the mini one when the sun shines and the metro one when it's raining.
Posting on here is to try and put some pressure on me to get this done.
These are the cars, the white one is to remain A-series, I think
#8 Feeble
Feeble
  • 1,094 posts
Posted 18 October 2006 - 08:11 PM
What does Mini based mean? I don't understand how these Midas cars are anything to do with Mini's... ;D
#9 Artstu
Artstu
  • 832 posts
Posted 18 October 2006 - 08:17 PM
All kit cars need a donor vehicle to supply the running gear, engine suspension etc. the Midas uses most of the mechanical bits off a mini, hence the term mini-based.
#10 Feeble
Feeble
  • 1,094 posts
Posted 18 October 2006 - 08:21 PM
Ah I see... They're kinda cool! ;D
#11 Artstu
Artstu
  • 832 posts
Posted 18 October 2006 - 08:30 PM
I like them, the body never goes rusty! all the minis I've ever had have always gone rusty, even brand new ones.
The Midas is a development of the mini marcos, seen below.
#12 Feeble
Feeble
  • 1,094 posts
Posted 18 October 2006 - 08:34 PM
Ahhh, now I recognise it! I thought 'where have I seen one of them before..?' ;D
#13 Artstu
Artstu
  • 832 posts
Posted 23 October 2006 - 05:29 PM
As I said a slow and steady conversion.
Cut some chunks out of the Metro subframe today, hope to see if an engine will fit in the gap tomorrow if I'm feeling strong.... no engine lift at the moment... hope to buy one real soon.
#14 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 23 October 2006 - 09:32 PM
look forward to reading this project. i love your 3rd midus, the shiny black one, makes me want one!
#15 Artstu
Artstu
  • 832 posts
Posted 24 October 2006 - 07:07 PM
Only had a few minutes today, the box goes in.
