Spark Plugs!
20 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 18 May 2019 - 08:16 AM
I have 3 sets of plugs. NGK B7ES BPR6ES BPR7ES
What’s the differences in practical use?
#2 unburntfuelinthemorning
  • 1,988 posts
Posted 18 May 2019 - 09:01 AM
B (shell) = 14mm thread x 13/16" hex   1.25mm pitch
P/R (construction) = projected insulator/resistor
6/7 (heat range) =  low number hot, high number cold plug
E (reach) = 19mm/3/4"
S (firing end construction) = standard 2.5mm copper core centre electrode
David Vizard suggests heat range 6 for standard use and up to 50% power increase; 7 for high output engines and 8 for race engines.
NGK plugs have a wide heat range but at the extremes:  if the plugs are too hot for the engine the electrodes get too hot and can cause pre-ignition; if too cold they can foul and misfire.
The resistor plugs suppress electrical interference which can otherwise affect electronics such as audio systems and engine management.
#3 1968andyf
1968andyf
  • 144 posts
Posted 18 May 2019 - 09:04 AM
The 7s are a colder plug than the 6s so would suit a more modified motor. The R denotes its a resistor plug
#4 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 18 May 2019 - 09:11 AM
Ok cheers for that. So am running custom fuel injection s/c 1293 so will use the 7 R then..!
#5 nicklouse
  • 18,678 posts
Posted 18 May 2019 - 10:00 AM
Fit the 6s go for a drive chop the plugs and see how they look.
7s will most likely be to cold.
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 18 May 2019 - 12:50 PM
Will give it a go, cheers!
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 18 May 2019 - 08:12 PM
The 7’s look a bit sooty after a short power run. Needs some RR diagnosis anyway. Running though.
#8 Cooperman
  • 23,322 posts
Posted 18 May 2019 - 08:16 PM
My Cooper 'S' has a 286 cam, 11.1:1 CR, twin H4 carbs, etc.
I always run BP6ES plugs and they are fine.
#9 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 19 May 2019 - 08:34 AM
Do people bother to set the gaps on them these days?
#10 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 19 May 2019 - 09:17 AM
I just check for damage and fire them on
#11 unburntfuelinthemorning
  • 1,988 posts
Posted 19 May 2019 - 03:01 PM
Some will some won't.  I would.  They're supposed to be a certain gap and it's easy enough to check.
#12 RooBoonix
RooBoonix
  • 1,225 posts
Posted 19 May 2019 - 03:09 PM
As said above for the time it takes, it's worth checking. Some engines/ignition systems are more sensitive to it than others
#13 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 20 May 2019 - 11:51 AM
What drives the gap measurement? I have a Haynes book but the engine in my car is quite modified from what the manual would have.
#14 unburntfuelinthemorning
  • 1,988 posts
Posted 20 May 2019 - 01:13 PM
Depends on the compression ratio and type of ignition system.  You won't go wrong with the basic 0.025" gap.  This could be opened up with a more powerful system.
#15 guywilko
guywilko
  • 46 posts
Posted 21 May 2019 - 12:33 PM
Running 40” on CSI electronic small bore high compression
