Spark Plugs!
20 replies to this topic
#16 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 21 May 2019 - 07:32 PM
Cheers, will get me feeler gauges out. It’s an s/c purpose built, ie no compression plates etc.
#17 Clubby77
Clubby77
  • 14 posts
Posted 22 May 2019 - 08:42 AM
The Gap depends on your Igninition System, if you have a points system you want it to be about 0,7mm.
If you have Points and constantly run High RPM i would even consider a smaller gap.
If you have electronic Ignition without Points you can consider going to 1mm which helps with cold starts and overall performance but puts a higher stress on your ignition System.
I would run the 6 only on a standard car. If you have a tuned car i would allways go for the 7's because if you are running lean in any Condition there is less risk, and the 6 will get way to hot if you give it a thrashing.
I have a 1330 with 115HP and i use 7's for normal use and 8s for trackdays and stuff.
G Jan
#18 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 23 May 2019 - 08:37 AM
Thanks for that. I am running Eaton super charger with twin injectotrs (not mpi, custom) and emerald ecu with ford coil pack. It was dyno at 149 after it was built a few years back. It’s not a daily driver, but does get a good spanking when out!!
Took it out last night with the 6’s gapped to 0.8 and it was jumping quite a bit when under load. Stopped, put the 7’s in, gapped to whatever they were out the box and it ran fine, much smoother under load. Took them out and 1 + 4 were sooty, 2 + 3 were light brown. It does need a remap on the rolling road, it’s been about 4 years since last setup, 6 years since total engine rebuild with addition of s/c.
#19 nicklouse
  • 18,679 posts
Posted 23 May 2019 - 08:44 AM
ahhhh now we have the full info.
supercharged. yes the 7s could be better suited.
#20 unburntfuelinthemorning
  • 1,988 posts
Posted 23 May 2019 - 10:51 AM
I too failed to see that s/c meant supercharged.
#21 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 23 May 2019 - 08:06 PM
Sorry, should have mentioned the super charged aspect! Thanks all, next stop to get it back on rollers.
