Tyre Fitting - Not Able To Fit 10S!
15 replies to this topic
#1 robj2502
robj2502
  • 136 posts
Posted 30 May 2019 - 03:33 PM
Has anyone else had an issue getting 10 inch tyres fitted? I went to 2 seperate tyre fitting places (both with very good reputations) last weekend and both were minimum 12inch rim size due to the minimum requirements of thier machine. Also is this even a thing or just bad choices/bad luck on my part?
Can anyone recomend a tyre fitting place that excepts 10inch wheels in south London/the early parts of Kent?
#2 imack
imack
  • 2,118 posts
Posted 30 May 2019 - 03:55 PM
Our equipment at work won't fit or balance 10's.
4 wheel alignment equipment doesn't fit either.
#3 robj2502
robj2502
  • 136 posts
Posted 30 May 2019 - 04:20 PM
This is proving to be a bit of a problem!!
Whilst I dont mind travelling to get tyres fitted (its not something you have to do on a regular basis afterall) it is still a PITA! Also I dont necessarily want to take my lovely, expensive, new wheels to Billy Bobs back road tyre fitters (unless there is a recommendation that is) as they are the only ones with old enough equipment to fit 10s
#4 Its a min
Its a min
  • 284 posts
Posted 30 May 2019 - 04:28 PM
just a thought but...
Try going onto one of the tyre sites like blackcircles. Search by tyre size, opt for fitted, enter your postcode and it should give you a list of garages within your selected area that should be able to fit them. Unfortunately, it isn't always up to date so you may need to ring but at least it'll give you an idea. Then see if you can find reviews on any of the garages.
Edited by Its a min, 30 May 2019 - 04:29 PM.
#5 imack
imack
  • 2,118 posts
Posted 30 May 2019 - 04:41 PM
I ended up fitting my 10's by hand, no tools. Fitted wheel to rear hub on car - hand brake on, plenty of soapy water and lots of effort and sore knees from pushing the tyres with my knees. Still couldn't balance them on our balancer so bought a cheap bubble balancer and spent ages modifying it to work properly.
#6 ukcooper
ukcooper
  • 1,625 posts
Posted 30 May 2019 - 04:48 PM
buy one off ebay for12's there old fashioned now try to get onr that dose 13" as well future proof
, plus make a few quid but get insurance for it
not mine and just one I pick off flebay  https://www.ebay.co....DIAAOSwIS5c6u-w
Edited by ukcooper, 30 May 2019 - 04:57 PM.
#7 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 30 May 2019 - 05:37 PM
A lot of tyre machines aren't able to clamp 10s... A mate has one that goes smaller. You'll have to search for a 10" friendly place bud. They do exist but they're few and far between.
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 30 May 2019 - 05:40 PM
Hi National tyres fitted mine and balanced them
#9 unburntfuelinthemorning
  • 1,984 posts
I've found the smaller companies to be really straightforward over the years.  I prefer to avoid the big names.
The one I currently live near was able to balance my 10s.
#10 Ethel
  • 25,951 posts
Posted 30 May 2019 - 06:02 PM
There are trailers still using 10's, might be a line of enquiry through local businesses.
#11 absx2
absx2
  • 916 posts
Posted 30 May 2019 - 06:28 PM
I have some 1/4" strips of leather and combined with the plastic protectors the machine will grab the rims good enough to fit the tyres at work.
No problems with balancing.
My Dunlops came with a label stating the warranty would be void if machine fitted but unlike thinner walled tyres they are very difficult to fit by hand and rubber mallet.
I popped a couple of Marshalls on with just my hands and a bit of tyre soap on 3.5" rims.
#12 robj2502
robj2502
  • 136 posts
Posted 31 May 2019 - 08:48 AM
Thanks for all of the replies.
Looks like im in for ringing around a few places! I will definately also try black circles just to narrow down the possibilties.
If not or if this proves to be extra difficult I may look at getting some of the equipment and doing it myself especially as I assume it will only get worse from here as tyre places replace thier machinery and as a general rule your average family car has giant wheels (it wouldnt surprise me if 18s were average size now!!)
#13 Norris73
Norris73
  • 105 posts
Posted 31 May 2019 - 10:22 AM
If you can get over to Ingatestone, Martin at LED tyres will sort you out. Say Olie sent you, and you should get a tyre fitted and balanced for £10. Ring ahead as he is a one man band, but he will sort it for you im sure. (He has fitted tyres with out issue to my standard 10" steel wheels).
His tracking gauges wont track 10" wheels though.
Edited by Norris73, 31 May 2019 - 10:23 AM.
#14 robj2502
robj2502
  • 136 posts
Posted 31 May 2019 - 10:42 AM
Thanks for this.
Its a bit of a trek but if I find no others local I will give him a shout.
#15 GraemeC
GraemeC
  • 7,438 posts
Posted 31 May 2019 - 11:24 AM
Proper old school garages will be more likely - the ones that can't afford to (or don't see the point in) buying shiney new equipment just 'because the salesman's been round
