http://cgi.ebay.co.u...Vie...:PIC&rd=1
Edited by Mark1275GT, 19 October 2006 - 11:25 PM.
Posted 19 October 2006 - 11:13 PM
Posted 19 October 2006 - 11:18 PM
Posted 19 October 2006 - 11:40 PM
sorry been edited??? you what? is what the correct coil??
Posted 20 October 2006 - 06:35 PM
Posted 20 October 2006 - 06:43 PM
hi is it a 1275 gt or a metro turbo with electric dizzy because if it has an elec dizzy then no i dont think it will work but if its a 1275 gt with points then yes i should work ?Is this the right Ignition Coil for my 1980 1275GT MG METRO TURBO ?
Posted 21 October 2006 - 03:01 PM
Posted 21 October 2006 - 05:18 PM
Posted 21 October 2006 - 05:48 PM
I just bought the same coil, the DLB105 Lucas sports coil is for all "A" series engines which are non ballast systems. The way to discover if you have a ballast or non ballast system is to look at the wires going to the coil.
If you have pink and yellow wires that is a ballast system, If the wires are white and white/black then that is a non ballast system which the DLB105 coil fit's.
However with a new engine in a older car who knows does the distributor have a black electronic module on the side of it. If so then the distributor is a electronic one.
I hope this helps
Edited by Mark1275GT, 21 October 2006 - 05:48 PM.
Posted 21 October 2006 - 06:11 PM
Posted 21 October 2006 - 06:18 PM
That looks like a vacuum unit. Do you have a vacuum pipe from the carb (might be through a tee piece) going into the side of the distributor. If so it sounds like a points and condensor style distributor. As for the wiring i would think you have a ballast system, but i am only guessing. Give Baldrick a call at Minispeed (i'm not sure of the number www.minispeed.co.uk) he should know.
Edited by Mark1275GT, 21 October 2006 - 06:21 PM.
Posted 21 October 2006 - 06:27 PM
Posted 21 October 2006 - 07:24 PM
Could u provide a pic to what it would look like inside the dizzy .. ?Was there supposed to be a picture attached to the last post lol. When you looked inside the dizzy cap was there a set of points as well, two bits of metal that open and close as the engine turns over. It does sound strange that a metro turbo lump would have a dizzy with a set of points, i would have thought it would have been electronic, but there we go.
ha ha!! i see the link. Still does not provide enough info. All you can see is that the wiring has been changed "modified" to suit the engine change. However that is one sweet looking engine bay, nice and clean.
Posted 25 October 2006 - 05:26 PM
Edited by Mark1275GT, 01 November 2006 - 09:29 PM.
Posted 01 November 2006 - 09:28 PM
Posted 02 November 2006 - 02:23 PM
Edited by Mark1275GT, 02 November 2006 - 02:41 PM.
