Advice On Coil Configuration
electrical engine
7 replies to this topic
#1 Miki Leyland
Miki Leyland
  • 125 posts
Posted 29 June 2019 - 02:58 PM
Hi there! Looking for some advice after reading some posts.
Two years ago I bought a coil for my 1973 Mk3 850 with ignition points, all the car being quite original ---> Lucas DLB101 non ballast. Worked perfect.
Last year after the old engine died I decided to upgrade the car a bit and went for a 998 +0.20 A+ flat piston engine, Stage2 and Hif38 with AAA, also with a new 59D4 electronic distrubutor. But previous coil and condenser were kept...
Is this the best coil option for me now or should I upgrade or change something for better performance?
Any comment appreciated
#2 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 29 June 2019 - 03:23 PM
Should be fine mate essentially any 12v coil set up correctly will be more then ample. I’m still running with ballast...
#3 Cooperman
  • 23,305 posts
Posted 29 June 2019 - 04:15 PM
That will be OK.
#4 unburntfuelinthemorning
  • 1,985 posts
Posted 29 June 2019 - 05:32 PM
As above but use the best quality parts.
#5 Miki Leyland
Miki Leyland
  • 125 posts
Posted 29 June 2019 - 05:38 PM
Thank you all
#6 Ethel
  • 25,988 posts
Posted 30 June 2019 - 08:21 AM
Depends, is your Type 59 converted to electronic or is it one of Lucas's own with external, and separate, amplifier?
If it is a factory version:
You need a GCL143 or equivalent, same as you would with a 65DM4.
...and the amplifier, of course
I think some of the older aftermarket kits ( Lumenition? ) use a ballasted coil, and were supplied with an actual resistor for the ballast.
#7 Ethel
  • 25,988 posts
Posted 30 June 2019 - 08:27 AM
Just noticed you mentioned a condenser, which rules out the factory unit pictured  >_<
#8 Miki Leyland
Miki Leyland
  • 125 posts
Posted 30 June 2019 - 08:42 AM
 https://www.minispar...px|Back to shop
This is the one I have...
Also tagged with one or more of these keywords: electrical, engine
