Sparkrite Sx4000
electrical engine
1 reply to this topic
#1 TylerDurden
TylerDurden
    Starting My Mini Up
  • 2 posts
Posted 24 September 2019 - 10:39 AM
HI all,
I was hoping somebody else has used or run a Accuspark Sparkrite SX4000 on a 998 mini.
I have fitted one but i am sure its not working correctly.
I have the static timing set @12 degrees
When I switch over to the sparkrite module the static timing adjusts itself to 5 degrees, when motor is reved to 4k or more the advance stays at 5 degrees.
When switching back to points the static advance is 12 degrees as expected and when reved upto 4k plus the advance goes up to around 30 degrees as expected.
Therefore i think the sparkrite box is not working as it's not letting the spark advance.
Any help greatly appreciated.
Tyler Durden.......
#2 nicklouse
  • 18,718 posts
Posted 24 September 2019 - 06:43 PM
I have alwZys found that the timing point is very diffetent between points and electronic.
Also tagged with one or more of these keywords: electrical, engine
