Rear Sub Frame Hessian Pads And Trailer Arm With Two Bearings?
suspension
9 replies to this topic
#1 Mogman
Mogman
  • Just Joined
  • 34 posts
Posted 30 September 2019 - 07:39 PM
Good Evening,
I'm doing Project Prim, and have a few questions.
Taken off the rear Sub-frame found rot so replacing with new. The old frame had three hessian pads between the frame and the body, one on each of the two side rails and one towards the front of the car. Not sure if they should be there (but they held water) or some one in the past has tried to reduce banging??? Photo of pads in wheel well.
Also one of the rear tailing arms has two roller bearings fitted. I have purchase rebuild kits for both rear arms and assume this is wrong and will have to replace with one bearing and one bush which need reaming, going to take to a local machine shop to do this part.
Thanks Chris and Lily
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 30 September 2019 - 07:50 PM
The hessian pads are there as standard for vibration / rubbing purposes. Chin them off and if you really want something there then use some thick rubber.
As for the radius arm with two bearings fitted, this does happen occasionally. You may find the bush will not fit if the outer dimension is not the same size as the roller bearing.
#3 Mogman
Mogman
  • Just Joined
  • 34 posts
Posted 30 September 2019 - 08:32 PM
Thick rubber sounds like a plan, I see what i can find.
Once i have removed the roller bearing will see if the bush will fit. Would it be to large a hole for it to hold the bush? or to small?
thnaks Neil for your reply
#4 DeadSquare
DeadSquare
  • 3,152 posts
Posted 30 September 2019 - 08:55 PM
Too large.
#5 sonikk4
sonikk4
  • 16,053 posts
  • Name: Neil
Posted 30 September 2019 - 09:05 PM
In your repair kits compare the external dia of the bush with the bearing. That will answer your question.
And as to Deadsquares blunt reply, i personally do not add anything, just make sure you have clearance between the subframe and floor. And when i say thick rubber, it needs to be no thicker than the hessian if you decide to go down that route.
#6 nicklouse
  • 18,654 posts
Posted 30 September 2019 - 09:13 PM
Two bearings is not uncommon where the bush had been worn through. the Metro had two bearings as standard.
#7 Mogman
Mogman
  • Just Joined
  • 34 posts
Thank You Both,
Hope the hole is not too large as new/refurbish arms are not cheap! Just googled them. jury is out on the rubber pads, will see how things look when offering up with some different size rubber pads to hand just in case.
Thanks again.
#8 Mogman
Mogman
  • Just Joined
  • 34 posts
Posted 30 September 2019 - 09:21 PM
The front has two roller bearings as I found when stripped, so is having two on the rear an issue, would be easier to have the other arm enlarged to accept a bearing so would match a metro or is this a frowned upon?
One of the arms was stiff can't rembember now which one, it may be because the roller bearing has be forced in and was to tight on the shaft?
Plan to remove the bearings once my new inner bearing puller arrives so may all become clear then.
#9 nicklouse
  • 18,654 posts
Posted 30 September 2019 - 09:50 PM
Re doing trailing arms yourself is not worth it. Just exchange them for some ready done ones. Then you don’t have to worry about reaming the bush to size and parallel with the bearing.
#10 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 01 October 2019 - 04:50 AM
As nick said not worth the repair, I’ve plenty of recon arms instock £60+ £40 exchange
Also tagged with one or more of these keywords: suspension
