Quick Shift Gear Lever
14 replies to this topic
#1 beardylondon
beardylondon
  • 1,727 posts
Posted 16 October 2019 - 11:50 AM
Is a quick shift gear lever worth fitting, the gear changes in my Mk1 (fitted with A+ engine) feel longer than the Cooper Mainstream.
Minispares one looks reasonable, but out of stock at the mo.
https://www.minispar.../C-22A1751.aspx
#2 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 16 October 2019 - 11:57 AM
I've read pro and cons on quick shifts. the original gear box have a huge travel, that is true. but it operates the gears change smoothly. the quick shiter are more brutal and people had problems with those if the gearbox is not in very good condition. I'm also hesitant on the topic, but I currently tend to think that, no, I won't put one in my car.
#3 nicklouse
  • 19,002 posts
Posted 16 October 2019 - 12:07 PM
first off wrong name. it is a travel reducer stick.
the speed is gearbox dependent.
I have always found that the cross car gate is too small.
fitted two back in the 90s. both went in the bin.
#4 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 16 October 2019 - 12:20 PM
I have a cheap one fitted from ebay, i read all the ups and downs but thought its not hard to change, my only difficulty is maybe 1 in 10 time selecting 1st gear is tricky. it still goes in with no grinding etc.
not that im using it to shift quickly, mini gearboxs dont like a quick shift.
#5 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 16 October 2019 - 12:38 PM
years ago I had a original KAD one.
Personally I found it great fun at first, though it doesn't take long until you're used to it then just feels normal. (until you drive another mini with standard gear shift!)
#6 unburntfuelinthemorning
  • 2,003 posts
Posted 16 October 2019 - 01:05 PM
I never thought the original gear change action was a problem when in good condition.  The Mini has always had a lovely feel when changing gear, better than a lot of more modern fare.  Saying that my mate has a "quick-shift" and thinks it's great.
#7 Tupers
Tupers
  • 4,173 posts
Posted 16 October 2019 - 03:41 PM
A quick shift won’t make up for worn bushes.
If the shift is noticeably sloppier than your other car it probably because the bushes in the selector housing and/or gearbox are worn.
#8 beardylondon
beardylondon
  • 1,727 posts
Posted 16 October 2019 - 06:08 PM
Thanks all, gearbox just been refurbished, only done 1200 miles.
#9 Tupers
Tupers
  • 4,173 posts
Posted 16 October 2019 - 06:23 PM
What about the selector housing bushes, mounting bobbins & the bush in the diff housing?
It’s worth popping the gear levers out of both and comparing the two balls on the bottom of them as they do also wear.
#10 Spider
  • 15,712 posts
Posted 16 October 2019 - 06:48 PM
I use the Mini Spares version and I do love them. Reverse is 'tight' to get but I'm fine with that, saves a red face.
However, as Tupers mentioned, all the Selector Mechanism parts do need to be in good order and I also found stiff mounts also helps a lot.
#11 beardylondon
beardylondon
  • 1,727 posts
Posted 16 October 2019 - 07:04 PM
Thanks all, will check all that
#12 beardylondon
beardylondon
  • 1,727 posts
Posted 18 October 2019 - 08:46 AM
@Tupers, I'll definitely update the 2 x rubber bobbins to poly ones.
Sorry if I'm being thick, but when you say bush in the diff housing, do you mean the gearbox selector metal and rubber oil seals, as they are new.
Also "selector housing bushes" do you mean this?
http://www.minispare...ck to catalogue
#13 beardylondon
beardylondon
  • 1,727 posts
Posted 19 October 2019 - 02:26 PM
Bump
#14 KTS
KTS
  • 2,490 posts
Posted 19 October 2019 - 08:05 PM
the selector housing bushes are the ones that support the selector rods in the shifter housing - one at the front and one at the rear
Can't remember off hand the bearing size, but there's a few threads that do refer to it
http://www.theminifo...du#entry3618966
Edited by KTS, 19 October 2019 - 08:10 PM.
#15 Zami
Zami
  • 185 posts
Posted 19 October 2019 - 11:48 PM
Fitted the minispares version to a fresh gear box 4/5 months ago. Works great and is a joy to use.
