Hot Start And Idle Problems
engine electrical
3 replies to this topic
#1 AndriusJur
AndriusJur
    Starting My Mini Up
  • 2 posts
Posted 22 October 2019 - 08:25 AM
Mini Mayfair '91
998, HS4 carb, electronic ignition, no mods.
Have problems with starting hot engine.
Firstly, when the engine is hot, when I turn the key there is no battery/charge light.
On cold engine it comes on and goes away after engine start.
Hot engine starts very unwillingly, it coughs, on idle rpms fluctuates between 400-700 and it tries to die.
Revving it up or pulling choke helps. So in order to be able to drive it i need to pull a choke more than half.
After several minutes it normalizes.
Also worth mentioning, that when the lights are on, on idle after revving the rpms drops very low, till 400 and then slowly climbs up till normal idle. Only choke helps not to stall. With lights off, rpms drops only to 700.
Recently I had replaced: coil, plugs, leads, rotor, cap, vacuum pipe. Dash oil topped up. Carb is new.
It runs much better, but problem still persists.
Have not find clues in forums. Any ideas?
#2 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 22 October 2019 - 11:46 AM
Firstly I would put a voltmeter on the alternator and see what Voltage its pushing out to see if the unit is doing its job properly.
Secondly what colour are the plugs when the engine is warm and not on the choke
#3 AndriusJur
AndriusJur
    Starting My Mini Up
  • 2 posts
Posted 22 October 2019 - 01:43 PM
Thanks! I will check alternator. Plugs were black before, so I leaned mixture, now they are more on the correct side.
#4 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 22 October 2019 - 02:19 PM
I wonder if you have leaned it off too much.. try riching it up a little to see if that improves it at all
Also tagged with one or more of these keywords: engine, electrical
