Thermostat Housing Temperature Sender Unit
20 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 12 November 2019 - 06:23 PM
Can anyone advise on the temperature sender unit for this housing please, I'm converting from SPI to carb and have looked for ages for a housing with sender hole. I have looked on Minispares and Minisport. This is allegedly from an MG metro engine ? tried Google but all come up with the original I need this to work with a Cooper carb loom I have to convert. I think this is a 10mm hole
Edited by I hate Brian, 12 November 2019 - 06:24 PM.
#2 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 12 November 2019 - 06:35 PM
Use Minispares.com P/N PEM10036 uses an 8mm sender
http://minispares.co...|Back to search
#3 Spider
  • 15,163 posts
Posted 12 November 2019 - 06:45 PM
Look for a 12A408 Thermostat Housing. They did fit them on some Morris Minors and some MG Models. They seem a little thin on the ground in the UK ?? but quite readily available in these parts;-
https://minisport.co...th-temp-adaptor
These take the stock Mini Temp sender.
#4 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 12 November 2019 - 06:54 PM
Yes Chris they are very thin on the ground here, as always yet more great advice
#5 I hate Brian
I hate Brian
  • 782 posts
Posted 12 November 2019 - 08:22 PM
Cheers gents I have requested a postage quote from Mini-bits in OZ for the mini/moke version I presume this will take the standard sender unit ??
Edited by I hate Brian, 12 November 2019 - 08:28 PM.
#6 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 12 November 2019 - 10:20 PM
It will indeed, I'd suggest using some PTFE tape or grease on the threads, purely to aid getting the sender out if you need to, I agree it may not be a good location for any grease or oily material but I'd much rather the sender came out ok as snap in place.
Hope this helps
Cal
#7 panky
panky
  • 1,792 posts
Posted 12 November 2019 - 11:44 PM
I'm guessing you know that this is for the temperature switch for the electric fan and not for the temp gauge.
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 13 November 2019 - 06:55 AM
Hi Panky to be honest no I didn't I would like the temperature gauge working as I'm also converting to a centre clock with oil and water any suggestions please on the best way forward.
Many thanks
Steve
#9 I hate Brian
I hate Brian
  • 782 posts
Posted 13 November 2019 - 07:08 AM
I thought could you use the temperature sender unit for the temp gauge, doesn't the electric fan work off the temp sender unit on the bottom of the radiator ??
Or if not have a manual switch for the electric fan ??
Thanks for any input in advance ;D
Edited by I hate Brian, 13 November 2019 - 07:22 AM.
#10 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 13 November 2019 - 09:37 AM
Any use?
http://www.dsnclassi...ont-retrosport/
#11 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 13 November 2019 - 09:43 AM
The fan does indeed work off the bottom radiator switch, but you can bypass and just have a switch in the cab
#12 panky
panky
  • 1,792 posts
Posted 13 November 2019 - 10:42 AM
Many thanks
Steve
Can't you use the normal position in the head for the gauge sender.
#13 panky
panky
  • 1,792 posts
Posted 13 November 2019 - 10:54 AM
The fan switch on the Metro/carb Cooper is in the sandwich plate, I guess yours is different being an SPI set up. I broke my temperature  switch so ended up fitting a manual switch as the sandwich plate ones are a bit expensive - and I very rarely need the fan anyway.
#14 I hate Brian
I hate Brian
  • 782 posts
Posted 13 November 2019 - 06:07 PM
SPI heads are not drilled for the normal sender position below the housing, the engine has just returned recently from keith Calver and set up ready to go never thought at the time about going centre clock and binacle, so I potentially I could of asked Keith at the time, I certainly don't want to attempt to drill and tap myself in fear of getting swarf in the water ways and galleries.
#15 stecolling
stecolling
    Starting My Mini Up
  • 1 posts
Posted 26 May 2023 - 02:50 PM
Did you ever come up with a solution for this? I find myself in the exact same predicament!
