Thermostat Housing Temperature Sender Unit
20 replies to this topic
#16 gav
gav
  • 700 posts
Posted 13 February 2024 - 03:37 PM
Look for a 12A408 Thermostat Housing. They did fit them on some Morris Minors and some MG Models. They seem a little thin on the ground in the UK ?? but quite readily available in these parts;-
https://minisport.co...th-temp-adaptor
These take the stock Mini Temp sender.
Thread bump... Do you know if the Morris Minor equivalent used a different thread? Seen some posts online which state 3/8 BSP?
#17 Spider
  • 15,165 posts
Posted 13 February 2024 - 07:06 PM
The only covers I have come across has a 5/8" UNF Thread with the tapered seat, just like that in the Heads.
I'm pretty sure I have one in the box, if I remember, I'll snap off some photos.
If I recall, Kilkenny Castings make them here;-
https://www.kcautopr...ingsmorris.html
WO16S
#18 gav
gav
  • 700 posts
Posted 14 February 2024 - 08:49 AM
WO16S
Many thanks!
#19 viz139
viz139
  • 682 posts
  • Local Club: Irish Mini Owners Club
Posted 14 February 2024 - 10:13 PM
Unlike the MPi this sensor does not control the auxiliary cooling fan, its controlled by the switch in the bottom of the rad.
#20 Spider
  • 15,165 posts
Posted 14 February 2024 - 11:44 PM
12A408
You can just see the seat in there
#21 MiniMarine
MiniMarine
  • 12 posts
Posted 29 May 2024 - 12:44 PM
Did you wind up using the suggested housing?  I've done the same conversion and am looking to use that housing as well.  Also how did you wire it in?  the SPI wiring went into the ECU did you by-pass that and go straight to the gauge? or is there something else that needs to be done to make the gauge work?
