Problems With Headlights
21 replies to this topic
#16 Rio
Rio
  • 85 posts
Posted 16 December 2019 - 08:28 AM
Thanks Graeme
Sounds like it but being brand new a couple of months ago, I was ruling it out plus I cant see anything.
If the plain blue wire comes up the column to the stalk and then there is a blue and red wire that I have tapped into, which coloured wire from the stalk is the main beam?
Andrew
#17 gazza82
gazza82
  • 2,919 posts
  • Local Club: TMF+
Posted 16 December 2019 - 09:26 AM
Blue White normally
#18 Rio
Rio
  • 85 posts
Posted 16 December 2019 - 10:39 AM
I agree Gazza but couldn't see that colour in the wiring loom going up or down to the steering column. :0
#19 Rio
Rio
  • 85 posts
Posted 17 December 2019 - 08:49 PM
That's what I am finding, must be another colour.
I can see the four separate inline fuses with the correct colours but behind the dash only
#20 KTS
KTS
  • 2,272 posts
Posted 17 December 2019 - 09:00 PM
check the multiplug connector on the main loom that the steering column loom connects to - find the blue/white wires and you can match it up against what's on the steering column side connector
#21 Rio
Rio
  • 85 posts
Posted 31 December 2019 - 02:19 PM
Found it :)
Was a faulty new indicator stalk. There was no connection or current going between the thick blue wire on the stalk to the plate where the contacts make.
Now soldered and all working
Just goes to show that although new, doesn't mean to say it's faulty
Thanks for everyone's advantage advice
Andrew
#22 andyapanel
andyapanel
  • 564 posts
Posted 01 January 2020 - 01:03 PM
I recently had a brand new one blow the horn section off for no apparent reason.
It was easy enough to repair, though.
