Rod Change Oil Seal
48 replies to this topic
#1 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 16 December 2019 - 09:12 AM
Hi Everyone,
I am very upset the rod change seal, All rod change in market are the same quality in MINIS sites. the part no. is AHU1672 it is fast leaking and ruined with heat especially in our hot weather.
anyone did an experiment using another seal for another car with the same seal size? Like seal with metal a heavy duty one. I don't know if TIMKEN producing same seal size
Regards,
#2 Spider
  • 15,123 posts
Posted 16 December 2019 - 09:37 AM
The problem is most likely not the seal.
The way the cases are machined, the shift shaft (which is in a rotating sleeve on the inside) often has too much play, well beyond what the seal - any seal - can take up. The other issue with the cimes from pounding the Roll Pin in and out with a hammer and punch, which cam distort the case.
Mini Spares have Anti-leak kits for these. Usually they will cure the leak.
#3 Chris1275gt
Chris1275gt
  • 965 posts
Posted 16 December 2019 - 01:45 PM
While beating it out is impossible to avoid I always squeeze a new pin in with a pair of water pump pliers with a new seal then your not stressing the naw seal.
Edited by Chris1275gt, 16 December 2019 - 01:49 PM.
#4 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 16 December 2019 - 08:31 PM
I have a stock of genuine rover seals if you are interested
#5 Spider
  • 15,123 posts
Posted 16 December 2019 - 11:36 PM
There is a tool that works like a G Clamp to press the pins out and I think they also can be used for getting them in, It is specific for this job on a Mini.
I thought I had a link but can't lay my hands on it. It did pop up on the forum - somewhere !
#6 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 December 2019 - 06:16 AM
I think you mean the below link
anyone know how to use it?
Edited by Kubbar, 17 December 2019 - 06:16 AM.
#7 Steve8274
Steve8274
  • 580 posts
Posted 17 December 2019 - 06:54 AM
That’s not the tool for removing it. That is something that can be used as a replacement when you have the old roll pin out. This aids quick fitting and removal of the rod. The tool is like an old measuring caliper.
#8 JXC Mini GT
JXC Mini GT
  • 853 posts
Posted 17 December 2019 - 06:55 AM
The minispares item isn’t a tool for removing the pins it’s a replacement item that can be fitted without the need to drift the pins in and can be fitted without the need for tools.
#9 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 17 December 2019 - 09:00 AM
Roll Pin Extractor Tools are widely available -but as i've never got around to buying one i've always used this method:
http://www.performan...itch/bitch.html
#10 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 December 2019 - 10:36 AM
i was thinking this is a tool thanks for this information
#11 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 17 December 2019 - 10:38 AM
Hi
do you know good brand for the seal better than in minis site
this seal every time leaking, I need better than this
#12 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 17 December 2019 - 10:54 AM
Is this the tool
https://www.ebay.co....AyABEgJCdPD_BwE
#13 Chris1275gt
Chris1275gt
  • 965 posts
Posted 17 December 2019 - 11:08 AM
That Minispares replacement looks to be the thing it won't improve any damage to my casing but it will ensure that it doesn't make it any worse than it is!
#14 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 17 December 2019 - 11:20 AM
Quite expensive though, and as I have more than one mini I would prefer the tool. That's an expensive conversion to do on a few cars, and of course you still have to get the existing roil pins out with a hammer and punch if you haven't got the tool, before you can fit the conversion.
#15 cian
cian
  • 869 posts
Posted 17 December 2019 - 12:36 PM
Hi
I have a stock of original rover rod seals and diff seals still in rover sealed bags
The op is looking at buying some, will need to check what I have remaining
