Sorry if this has been asked before, did a search but couldn't find anything...
Is there a database online somewhere where you can check your Mini's date of fabrication ?
The plates are as follows :
- Car N° (top of radiator frame) AA2SBD - 13258***
- Commission N° 2/155 0503***
Reversed Stamped Plates :
- Crossbar L090***
- Above Radiator FE1443***
- Interior Footwell FO54***
Cheers !
MK2 Austin - Build Date ???
Gibbon
, Oct 24 2006 11:00 AM
5 replies to this topic
Posted 24 October 2006 - 11:00 AM
Posted 24 October 2006 - 10:22 PM
all i know is that production started in October 1967 with chassis number A/A2SB 1068001.
and ended in December 1969 with chassis number A/A2SB 1372023.
i think the "D" stands for longbridge (it does on rover coopers)
if you assume that production followed a steady quantity of cars then you can work out an approximate date from this but you should be able to get a heritage certificate from gaydon.
look them up on the web
Posted 25 October 2006 - 03:32 AM
thats strange because mine was built 3 august 1967 and chassis number was 493792 so that means that there were 574309 built from 3 august 1967 untill october 1967.
Posted 25 October 2006 - 05:05 PM
are you sure yours is an austin mini ???
these figures are for Austins, the Morris figures are M/A2S6 507001 and M/A2S6 713901 respectively.
Posted 25 October 2006 - 06:04 PM
sorry mr anorack, i did not realise that was just for austins, mine is a morris and show it was built 13,209 before the start of the mk2s. would be nice to know if mine is the last one surviving before the mk2s started.
Posted 26 October 2006 - 06:17 AM
If I go with Mr Anorak's train of thought...
That would put my build date around Aug or September '69
- 27 months production
- 304,022 cars produced
- 11,260 cars produced per month
