knocking on heavens door
Posted 24 October 2006 - 12:48 PM
i have a knocking noise coming from the engine bay ... suspect = worn bushes BUT have now checked all of these and they are fine, besides i only replaced the frame and engine a few months ago with new bits all round. There is plenty of clearance between carb and bulkhead so it ain't that. Sounds as if coming from lower down as well.
It occurs when pulling away, or generally changing speed .... i feel like it may be something to do with the steering rack ?? could a worn joint be causing me this ? but then there is no knock when turning the wheel, going round corners etc.
Any further suggestions or help be grateful as I can no longer take the noise (plus i dont have a stereo so i cant ignore it!! ha ha ... )
thanking you
manifesto-mini
Posted 24 October 2006 - 12:52 PM
Maybe the exhaust knocking somewhere?
Maybe an engine steady?
Posted 24 October 2006 - 12:59 PM
Could be you need to uprate your steady bar bushes.
Matt
Posted 24 October 2006 - 01:01 PM
Edited by theoldtartspimp, 24 October 2006 - 01:04 PM.
Posted 24 October 2006 - 01:18 PM
Does it do it when you lift off the accelerator? and when you put it back on?
Matt
well, yes and no (good answer heh!) it does tend to happen more when lifting the clutch up or when slowing down so it does sound like steady bar bushes ... mmm
thanks for this help by the way!
Edited by manifesto-mini, 24 October 2006 - 01:19 PM.
Posted 24 October 2006 - 02:24 PM
Ultimate engine steady isn't the answer, the stock steady should be enough not to have serious knocks coming. Fix the problem rather than cover it up
Good luck!
Posted 24 October 2006 - 06:19 PM
Posted 25 October 2006 - 11:28 AM
Have a look at the bulkhead where the engine steady connects just under the master cylinders, is it all solid?
Has the gearbox steady snapped and is now knocking?
I was going to suggest looking at the ultimate engine steady if you had one connected, I once forgot to tighten this up at the bulkhead end and it was knocking.
Also, physically try and move things like the exhaust manifold and gear linkage, things that are connected to both the engine and body, you may find something has a bit of movement in it that would cause knocking.
Another thing I've heard of is where the subframe bolts to the floor, if the floorpan cracks it can cause a knocking sound.
Posted 25 October 2006 - 03:56 PM
the local garage told him his gear box had gone
after giving the garage a lot of money for replacing the box it still made the same noise
i lifted the carpet in the drivers foot well and found the problem
the floor plan had cracked just under the subframe mount
same garage also gave him a MOT with this crack in the floor
Posted 28 October 2006 - 04:28 PM
Posted 28 October 2006 - 05:33 PM
Posted 28 October 2006 - 06:04 PM
Some time later, the subframe mounts had parted and i went to pull away with my usuall gusto, and the front seam finishers flew off as the whole front end tried to separate itself from the rest of the car!!!
The same car had a drop bracket fitted which resulted in the steering column breaking ... thankfully i had just pulled into a layby at the time!!!!!
Posted 28 October 2006 - 06:05 PM
