Hi Everyone
I would like to share you my issue with my wiper on MPI, the wiper is not stop when I turn it off from stalk the wiper speed is working good, I change and check the following:
1) changing the park switch
2) check the relay is good (yellow)
3) check the wiper control unit relay (red)
4) changing the wiper stalk inside
5) check fuse is good
what else I have to check? do I have to change wiper motor plug? or this maybe an issue with the wiper motor ?
hope I can find the issue and you can help me to fix this issue
Regards,
