Which Oil Mpi Engine ?
Posted 19 January 2020 - 03:05 PM
Thank you all ??
Posted 19 January 2020 - 03:37 PM
I use Millers Classic Mini Oil in mine.
Posted 19 January 2020 - 07:11 PM
Thanks is that an mpi ?
Posted 19 January 2020 - 07:15 PM
Is it manual or Auto transmission?
Posted 19 January 2020 - 07:26 PM
Yes, a '98.
Posted 19 January 2020 - 07:32 PM
Yes, a '98.
Thanks is that an mpi ?I use Millers Classic Mini Oil in mine.
Brilliant thank you mate ??
Posted 20 January 2020 - 06:14 PM
Going on from what Nick asked, autos like a different oil compared to manuals so it's worth thinking about if you have one.
Posted 20 January 2020 - 06:23 PM
Yes, a '98.
Your Kat will not like it.
Posted 20 January 2020 - 06:26 PM
https://www.opieoils...engine-oil.aspx
Edited by jamesmpi, 20 January 2020 - 06:26 PM.
Posted 21 January 2020 - 07:50 PM
My Kat will not like it ? What do you recommend ?
Yes, a '98.
Posted 22 January 2020 - 11:37 AM
Posted 22 January 2020 - 11:39 AM
Millers or MiniSpares own brand.
Posted 22 January 2020 - 06:40 PM
Why won’t my Kat like it nicklouse ?
Posted 24 January 2020 - 02:56 AM
I suspect the comment about the catalytic converter is related to zinc levels. The so-called "classic" oils boast higher levels of zinc diphosphate (ZDDP), which serves as an anti-wear additive to motor oil. This additive can "poison" catalytic converters, rendering them less effective over long periods of time.
My own personal opinion is that the issue of ZDDP is vastly overrated. The issue first came up in the mid-2000's as claims of excessive wear on flat tappet cams cam up. This was blamed on reduced ZDDP levels.
I'm not convinced this was ever the case - I suspect deficient metallurgy from cheapened production sources as the true culprit. Here's why:
1) Massive levels of ZDDP don't equate to greater protection. Only so much ZDDP binds to metal surface at any given time. It doesn't keep plating itself on thicker and thicker. High levels can be useful for break-in because there is no protective layer of ZDDP on fresh metal. ZDDP bonds as a result of high pressures and temperatures - so racing engines may deplete this faster.
2) It is akin to vitamins in the human body - taking 10,000x the daily recommended dose of vitamins does little if any good. If your body can't use it, it just makes you see funny colors when you visit the restroom after a night at the pub. Your body gets rid of what it can't use. ZDDP just stays in the oil unused.
If you did an oil test after a change, and found that the levels were very low compared to what you had when the oil was fresh, then that could justify using a oil with a higher level of ZDDP.
But also note that oil companies aren't stupid - they've long since found alternatives to ZDDP for high-load wear protection, and the current oils meet all the national standards for oil wear and protection (which apply to all cars, not just the latest models.) Especially consider that modern engines have higher tolerances than many classic cars, so if they wear out faster, it seems they would be affected sooner.
Flat tappet cams are hardly the only area subject to high temperatures and friction. So why aren't the rings and bearings wearing out faster because of lack of ZDDP? It's not like modern engines have all switched to roller-bearing crankshafts or anything like that.
And in fact, if you want to get nitpicky, ZDDP actually increases friction in the motor (though it decreases wear, because it's sacrificing itself in the process instead of the base metal surface.) Probably immeasurably low on a engine dyno, but some racers think it's worth avoiding and use oils with other anti-wear additives.
After all these years I've yet to come across a scientific study showing that flat-tappet cams are being killed through lack of ZDDP. It's anecdotal testimony - builder X says this, builder Y says that. That isn't worthless, but it's not scientific.
They don't know for sure it's the lack of ZDDP that did it. They don't have a control set and an test set to compare against. It's why so many of them rail against synthetic oil - same deal. They see a failure and say the oil is the cause. But how do they really know without a metallurgic analysis at least?
Dave
Posted 24 January 2020 - 07:56 AM
But is there any “scientific study showing that... ZDDP additive” does "poison" catalytic converters, rendering them less effective over long periods of time”, in normal use, on a well maintained engine?
