Hi Lo Ratio
Posted 21 February 2020 - 07:12 PM
Posted 21 February 2020 - 07:14 PM
Posted 21 February 2020 - 11:08 PM
http://www.theminifo...-fitting-guide/
In the post by Sprocket at the bottom
Sadly, he's followed the same error that Clive Trickey published back in the 60's for the Fronts and everyone has followed since.
The Front Ratio (when using Dry Arms) is 4.45:1 and the Rear Ratio is 5:1.
Most of the common Hilos these days use an M20 x 2.5 Bolt.
So, turning the Bolt 1 Flat;-
on the Front changes the height by 1.9 mm
on the Rear changes the height by 2.1 mm
1 complete turn (6 flats);-
on the Front changes the height by 11 mm
on the Rear changes the height by 12.5 mm
Posted 21 February 2020 - 11:11 PM
I had forgotten that and I have to set the ride height on my 1990 Cooper next week, so thanks for the up-date.
Posted 22 February 2020 - 01:15 AM
While I haven't put any numbers on this, just looking at the Arm, it's fairly evident that the ratio isn't even close to 3:1
Posted 22 February 2020 - 10:00 AM
on the Front changes the height by 1.9 mmon the Rear changes the height by 2.1 mm
Thanks for that. Very usefull. My Hilos are fianally at my machine shop friend for modifing
Posted 22 February 2020 - 10:14 AM
by the way, this info should be a sticky
Posted 22 February 2020 - 11:30 AM
And doing some very rough measurements on the picture confirms your numbers.
Posted 22 February 2020 - 01:19 PM
Measurement of the height change would be the only way to say for sure.
Posted 22 February 2020 - 02:31 PM
Posted 22 February 2020 - 06:41 PM
Well the arm is almost horizontal so the trigonometry would only change the figures a tinywiny bit, the wear on the tyres would make more of a difference. ?Is measuring along the arm enough? That’ll give you the leverage ratio but you’d need a bit of trigonometry to work out the height change I think.
Posted 23 February 2020 - 06:24 AM
Yes, for sure Graeme, but the numbers I've quoted are for better then ball park.
